#2369: opengisch/OSGeo4A transfer to OSGeo github
Reporter: mbernasocchi | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
While building QField we created a complete set of build scripts for geo-
related libs on android (similar to OSGeo4W)
https://github.com/opengisch/OSGeo4A
it is basically an SDK for any OSGeo/QGIS based android app and we'd like
to transfer this under the umbrella of Osgeo.
due to its nature (It allows building GDAL, PROJ and so on), we think that
it would be a much better fit there than under our company.
We would obviously still work a lot on it but it would avoid having to
reinvent the wheel for other projects and it could foster synergies.
What are the requirements to put it on https://github.com/osgeo
Marco
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2369>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by rouault):
I'm in favor of this. We have homebrew-osgeo4mac and osgeo4freebsd
repositories with similar purposes under the OSGeo github account.
I should have sufficient rights on OSGeo github account to do what is
needed. Is there some migration functionality or should I just create a
OSGeo4A repo and give you push rights on it ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2369#comment:1>
Keywords: |
Comment (by mbernasocchi):
Nope, it has to start from our side. I can transfer ownership directly
when I get an ok from you guys at OSGeo.
Then you would have to give maintainer or admin (depends on your policies)
rights to @mbernasocchi and @m-kuhn
and write rights to @3nids @marioba and @signedav
Thanks a lot Even
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2369#comment:2>
Keywords: |
I suck at GitHub right management. I believe that @mbernasocchi and
@m-kuhn should have received an invitation with sufficient priviledges.
You should be able to give additional rights to other people hopefully
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2369#comment:3>
Keywords: |
Thanks, I've accepted it and definitely got enough permissions. Now the
question is can you give me an official OK or do you need to discuss
internally?
Merci
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2369#comment:4>
Keywords: |
I've no idea if there's an official process, and who would be responsible
for the decision making. In the past, we just did that rather informally.
You're well-know people from the community, the stuff is open source &
geo-related. Just go ahead !
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2369#comment:5>
Keywords: |
ok, great! worse case we revert it
Marco
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2369#comment:6>
Type: task | Status: closed
Component: Systems Admin | Resolution: wontfix
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
assume whatever this is is set
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2369#comment:7>
