#2385: Provide a docker registry
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Installing, for example: http://port.us.org/ (which supports LDAP)
This is an actionable item for #2204
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2385>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
My understanding is that Portus is only the authentication layer, the
actual registry would be https://github.com/docker/distribution
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2385#comment:1>
Keywords: |
Comment (by strk):
Another option is described here: https://weblog.wemanity.com/docker-
registry-docker-hub-at-home-for-free/
It still uses github.com/docker/distribution for the registry itself but
uses https://hub.docker.com/r/cesanta/docker_auth/ for authentication
(also supports LDAP)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2385#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
This was done a long time ago.
We now have https://repo.osgeo.org which includes a docker registry that
utilizes our ldap authentication.
currently being used by sac, geoserver, geos, and postgis
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2385#comment:3>
