#2386: FOSS4G Europe 2020 website and domain redirection
Reporter: jachym | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Hi SAC,
we need to redirect europe.foss4g.org to some server, where we are going
to host conference web page.
we would like to use drupal.
is it possible to get access to osgeo servers?
or shell we start the server by ourselves now and you will just redirect
the DNS record.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2386>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by jachym):
it's going to be wordpress then
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2386#comment:1>
Keywords: |
Comment (by robe):
jachym I can set up a wordpress instance for this. Should I go ahead and
do that and change europe.foss4g.org to point to the new instance.
Alternatively I can give it a dummy name like staging.europe.foss4g.org so
you can start working on it and switch the production domain once you are
ready.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2386#comment:2>
Priority: normal | Milestone: Sysadmin Contract 2019-II
Keywords: |
Changes (by robe):
* milestone: => Sysadmin Contract 2019-II
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2386#comment:3>
Keywords: |
Comment (by peterisb):
robe, yes let's set up instance and change europe.foss4g.org to point to
the new instance.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2386#comment:4>
Keywords: |
Comment (by robe):
Okay I'll get that up today. It turns out I can't just repoint the europe
one. I'm in the middle of migrating the old web-extra server -- so I'm
going to recode the way this is done.
right now it is in apache and each year has a proxy redirect to the
corresponding web host.
I'm going to move it to nginx -- and then have the new wordpress be the
2020
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2386#comment:5>
Keywords: |
Comment (by robe):
Okay I created a wordpress site and added both of you (jachym, peterisb)
as admins. You should have gotten an email to that effect.
https://2020.europe.foss4g.org
I also changed the default home for europe.foss4g.org to redirect to this
(replacing the 2018)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2386#comment:6>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
If you need anything else let me know
I can for example set up a private git repo on gitea with the basic
configs in case you need to change them.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2386#comment:7>
Keywords: |
Comment (by robe):
Just a side note -- I thought it was my moving the webextra VM when I
noticed 2018 is down https://europe.foss4g.org/2017/ . I concluded though
that it's the domain because when I tried get to it directly - https
://foss4g-europe.osgeopt.pt I couldn't. And I'm pretty sure it was
working last week when I tested it.
https://europe.foss4g.org/2017/ works fine
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2386#comment:8>
Keywords: |
Thanks, works!
Replying to [comment:8 robe]:
noticed 2018 is down https://europe.foss4g.org/2018/ . I concluded though
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2386#comment:9>
