[SAC] [OSGeo] #2395: Bad redirection
Reporter: cvvergara | Owner: sac@…
     Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
https://osgeo.org/
redirects to
https://www.osgeo.org/community/getting-started-osgeo/osgeo_userid/
instead of:
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2395&gt;
OSGeo <https://osgeo.org/&gt;
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I think the redirect is set on old.www.osgeo.org now on old-www container.
I couldn't find it in the apache config, so assume it must be done at the
drupal level somewhere.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2395#comment:1&gt;
Keywords: |
Comment (by wildintellect):
It's definitely loading an html page, not using apache. Any reason we
can't solve this with an update to DNS, and then the redirect should
happen on the nginx instance?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2395#comment:2&gt;
Keywords: |
Comment (by robe):
it does more than redirect osgeo.org.
That is sitting on old.www.osgeo.org and redirects a whole bunch of other
things.
So I think if you repointed it I suspect other things would break.
We could try and then revert if hell breaks loose.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2395#comment:3&gt;
Keywords: |
We should try to track down where that actually happens. I poked around,
you may be right that it's in Drupal, in which case maybe all of the
redirects are stored in a single table we can dump?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2395#comment:4&gt;
     Type: task | Status: closed
Component: SysAdmin | Resolution: fixed
Keywords: |
Changes (by strk):
* resolution: => fixed
* status: new => closed
Comment:
Seems fixed now
Ticket URL: <Making sure you're not a bot!;
OSGeo <Gter - OSGeo;
