#2410: artifact manager to replace download.osgeo.org/webdav/geotools
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Planet has informed us that they would like to retire
repo.boundlessgeo.com (an artifactory instance) used by the GeoServer
project. The GeoServer PSC would like to ask OSGeo if it is possible to
host an artifact manager on OSGeo hardware?
As discussed in 2019 (see https://trac.osgeo.org/osgeo/ticket/2261) this
is a good oppertunity to setup an artifact manager to replace
http://download.osgeo.org/webdav/geotools/
There are two good options:
* https://jfrog.com/open-source/ - easy to manage
* https://www.sonatype.com/download-oss-sonatype - does slightly more
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by jive):
This is a somewhat time sensitive activity as we would like to rescue the
contents of repo.boundlessgeo.com (mostly prior release of GeoServer and
GeoWebCache).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:1>
Keywords: |
Comment (by jive):
As noted in email discussion these repository managers can be configured
to manage maven, docker, node, etc... and may be of interest to a sider
group of osgeo projects.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:2>
Keywords: |
Comment (by wildintellect):
Possible: Yes
How: we need some members to step up to set up a container dedicated to
this purpose and hopefully have some expertise or at least time to vet the
options.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:3>
Keywords: |
Comment (by robe):
jive -- as a clean replacement sounds like might be better to go with
jfrog since that is what repo.boundlessgeo.com is using.
What does sonatype do additional that jfrog doesn't that would be a
possible need?
I'd be willing to take a stab at installing it -- you have details of how
we can pull over the artifacts from boundless?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:4>
Keywords: |
Comment (by jive):
Answering your question *What does sonatype do additional that jfrog
doesn't that would be a possible need?*
Frog artifactory:
* personal experience: easier administration screens to manage
* Only supports java projects (Maven, Gradle and Ivy)
* Used by repo.boundlessgeo.com (after a poor experience with cloud
hosting)
Nexus:
* personal experience: more complicated administration screens
* This is the clear choice for OSGeo as it offers capabilities for more
than just java projects (docker images, node packages, ruby, python, go,
etc...)
* Used by eclipse foundation (with their strong emphasis on control),
I have personally used both as an administrator (not installing but
managing).
Links:
* https://www.sonatype.com/nexus-repository-oss
* https://sonatype.drift.click/oss-vs-pro
* https://info.sonatype.com/nexus-vs-artifactory
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:5>
Keywords: |
Comment (by jive):
I think to copy the contents Tom Ingold did:
1. Set up repo as a cache of old repo
2. Have a script that accessed all the content via the new URL
3. Turn of the "cache" and keep the content
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:6>
Keywords: |
Comment (by jive):
So what happens next?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:7>
Keywords: |
Comment (by robe):
jive,
I'm planning to setup osgeo3 this week and thinking I would set up a
container for nexus and jfrog.
I'm thinking maybe it would be easier if I setup jfrog first that way you
have a clean migration from boundless? and then we can do nexus and
slowly port over?
I don't think it's necessary for all projects to use the same thing so if
you feel more comfortable with artifactory I'd say you should use that.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:8>
Priority: normal | Milestone: Sysadmin Contract 2020-I
Keywords: |
Changes (by robe):
* milestone: => Sysadmin Contract 2020-I
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:9>
Keywords: |
Comment (by robe):
Jody - I setup nexus using the docker container from here
https://hub.docker.com/r/sonatype/nexus3/ - I sent you the login details
https://nexus.osgeo.org
It's running in a dedicated LXD OS container so we could put other dockery
stuff in there you need.
It's running on the new osgeo3 lxd host I set up today.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:10>
Keywords: |
Comment (by robe):
nexus supports LDAP so I configured it to use OSGeo LDAP and set jive,
wildintellect, strk as an admins.
There is a setting in the LDAP config to use LDAP groups for role
management. But I wasn't sure if we wanted to do that for the first go
round.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:11>
Keywords: |
Comment (by robe):
based on popular demand I have added
https://repo.osgeo.org as an alias for https://nexus.osgeo.org
we can get rid of nexus but that's what the container is called and the
config I have at moment and some other names were proposed like
docker.osgeo.org, apt.osgeo.org etc.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:12>
Keywords: |
Comment (by jive):
Thanks for the hard work, I am collecting notes on how to transfer
content.
1. webdav
This [https://community.sonatype.com/t/nexus-repository-artifact-import-
scripts/1254 script] would like to be run on osgeo machine hosting webdav
folder.
This replies on direct file system access and should be fairly quick.
* to: https://repo.osgeo.org/geotools-releases
Once content is migrated we can redirect
http://download.osgeo.org/webdav/geotools/ --> repo.osgeo.org/release
2. repo.boundlessgeo.com to
This [https://github.com/simpligility/maven-repository-tools/tree/master
/maven-repository-provisioner maven repository provisioner] can be run
from anywhere, and just uses maven API.
* from: https://repo.boundlessgeo.com/artifactory/release
* to: https://repo.osgeo.org/geoserver-releases
I expect this will be quite bandwidth intensive, as such I would prefer to
run this script on osgeo hardware.
3. when complete
Update the builds for osgeo projects and communicate the change to
downstream applications
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:13>
Keywords: |
Comment (by robe):
jive are you all set here? Last we discussed you had root access to nexus
container and download container and can install anything you need on the
nexus container.
I also want to do an upgrade of nexus install to deal with vulnerability
that was announced a couple of days ago. I'm not sure you have any groovy
scripts so may be a non-issue.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:14>
Keywords: |
Comment (by robe):
I did the upgrade on nexus.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:15>
Keywords: |
Comment (by jive):
Tom Ingold was able to transfer content from
https://repo.boundlessgeo.com/artifactory/release to Geoserver-releases
(no idea why that ended up with a capital but it does not matter so much
as it mostly an internal detail). The maven repository provisioner did
not work, but he was able to figure some scripts out (wget, find, xargs
and curl).
Initial testing found that some things were missed (apache beanutils) so
some testing is needed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:16>
Keywords: |
Comment (by jive):
I have written up a wiki page https://wiki.osgeo.org/wiki/SAC:Repo
describing how projects can join the repository.
We have our initial builds working from GeoTools, I think this issue can
be closed!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:17>
Keywords: |
Comment (by jive):
aside: I was able to complete migrating contents from webdav folder.
Should we make plans to shutoff that webdav folder, or redirect to
https://repo.osgeo.org/repository/release/ ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:18>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2410#comment:19>
