#2425: snapshots failing on osgeo7
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2020-I
Component: Systems Admin | Keywords:
As mentioned in my other ticket. Other issue with osgeo7 is the lxd
snapshots process is failing.
Sounds like the same issue as described here
https://github.com/lxc/lxd/issues/7024
So I'm going to try the fix mentioned in that thread
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2425>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Old description:
New description:
For completeness the error before the fix was
UNIQUE constraint failed: storage_volumes_snapshots.id lxc snapshot
Comment:
okay I applied the fix as described in that ticket and seems to have fixed
the snapshot error
-- returned 4360
lxd sql global "SELECT MAX(id) FROM storage_volumes_all LIMIT 1;"
lxd sql global "UPDATE sqlite_sequence SET seq = 4360 WHERE name =
'storage_volumes'"
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2425#comment:1>
