#2433: old-web: irqbalance: WARNING, didn't collect load info for all cpus,
balancing is broken
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2020-I
Component: Systems Admin | Keywords:
I found many such lines in /var/log/syslog, sounds like something to fix:
Apr 7 06:52:42 old-web /usr/sbin/irqbalance: WARNING, didn't collect load
info for all cpus, balancing is broken
Apr 7 06:52:52 old-web /usr/sbin/irqbalance: WARNING, didn't collect load
Apr 7 06:53:02 old-web /usr/sbin/irqbalance: WARNING, didn't collect load
Apr 7 06:53:12 old-web /usr/sbin/irqbalance: WARNING, didn't collect load
Apr 7 06:53:22 old-web /usr/sbin/irqbalance: WARNING, didn't collect load
Apr 7 06:53:32 old-web /usr/sbin/irqbalance: WARNING, didn't collect load
Apr 7 06:53:42 old-web /usr/sbin/irqbalance: WARNING, didn't collect load
Apr 7 06:53:52 old-web /usr/sbin/irqbalance: WARNING, didn't collect load
Apr 7 06:54:02 old-web /usr/sbin/irqbalance: WARNING, didn't collect load
Apr 7 06:54:12 old-web /usr/sbin/irqbalance: WARNING, didn't collect load
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2433>
OSGeo <https://osgeo.org/>
balancing is broken
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I think I need to reboot osgeo7 since the lxd 4 upgrade -- doing things
like lxc list are slow.
I suspect it will fix this issue as well, though maybe rebooting old-web
might be sufficient as I think that might be one where I had to unmount
the proc things and I might not have restarted after. I'll do that first.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2433#comment:1>
balancing is broken
Keywords: |
Comment (by robe):
I tried rebooting but that didn't make the message go away. Stuff I've
read suggests this service may not be needed particularly in a virtual
environment. So I stopped the service for now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2433#comment:2>
balancing is broken
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
going to close this and reopen if shutting the service caused any issues.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2433#comment:3>
