#2438: Create a geos and postgis docker repo on repo.osgeo.org
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Okay I think I got this working. I created a new docker.osgeo.org nginx
config dedicated. I could put it all in the nexus one, but felt might be
better to keep it separate. I'm planning to eventually take out all the
/v2 stuff I put in on the nexus config.
So the way it works, all pushes must go thru the project repo
e.g postgis-docker.osgeo.org, geoserver-docker.osgeo.org, geos-
docker.osgeo.org
But pulls go thru
docker.osgeo.org
To test I copied over strk's images:
docker pull docker.kbt.io/postgis/build-test:trisquel2
docker tag docker.kbt.io/postgis/build-test:trisquel2 postgis-
docker.osgeo.org/postgis/build-test:trisquel2
docker push postgis-docker.osgeo.org/postgis/build-test:trisquel2
and that shows a new image in postgis-docker repository folder (and of
course exposed in the docker group
committed at -
https://git.osgeo.org/gitea/sac/osgeo3/commit/87932245f05841f0413053e5f824dc0cd5bfae46
So key area of nginx script looks like this sorry about the crappy
indentation, going to fix that next
location ~ ^/(v1|v2)/[^/]+/?[^/]+/blobs/ {
if ($request_method ~* (GET) ){
rewrite ^/(.*)$ /repository/docker/$1 last;
if ($host = postgis-docker.osgeo.org ){
rewrite ^/(.*)$ /repository/postgis-docker/$1 last;
if ($host = geos-docker.osgeo.org ){
rewrite ^/(.*)$ /repository/geos-docker/$1 last;
if ($host = geoserver-docker.osgeo.org ) {
rewrite ^(.*)$ /repository/geoserver-docker/$1 last;
location ~ ^/(v1|v2)/ {
if ($host = postgis-docker.osgeo.org ) {
last;
if ($host = geos-docker.osgeo.org ) {
rewrite ^/(.*)$ /repository/geoserver-docker/$1
last;
location / {
# First attempt to serve request as file, then
# as directory, then fall back to displaying a 404.
#try_files $uri $uri/ =404;
client_max_body_size 0;
include /etc/nginx/proxy_protocol_params;
#need to change this if using https on server and have a
redirect
proxy_pass http://nexus.lxd:8081;
proxy_redirect off;
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2438#comment:14>
OSGeo <https://osgeo.org/>
