#244: GRASS trac: install TOC macro from http://trac-hacks.org/wiki/TocMacro
Reporter: neteler | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: normal | Component: SAC
Keywords: trac |
Please someone capable install the TOC macro from http://trac-
I tried and created a Python egg as requested in the trac admin plugin
management section:
cd /tmp/tocmacro/0.10/
python setup.py bdist_egg
as explained in http://peak.telecommunity.com/DevCenter/PythonEggs#
building-eggs
When uploading the resulting dist/TracTocMacro-1.0-py2.5.egg it fails with
Internal Error
No file uploaded
Possibly, because I use Python 2.5? Not sure which Python version is
needed, also
a Python 2.4 egg failed.
Maybe only command line upload works? (I have no access)
I assume that this macro is of wide interest for all OSGeo tracs.
thanks,
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/244>
OSGeo <http://www.osgeo.org/>
