#2449: Setup Grafana and Prometheus for monitoring of servers
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2020-I
Component: Systems Admin | Keywords:
When I killed off the old osgeo3, I made all the munin-nodes no longer
useful.
I started to setup a new munin -- but couldn't get it to work -- which got
me thinking maybe there is something better anyway.
Long story short -- after accidentally stumbling on some videos about
Matrix, I came across a combination of using Prometheus with Grafana and
it ended up surprisingly easy to install.
I've only installed nodes so far on the newer servers on osgeo3 and
started to do it on osgeo7.
The web interface for the monitoring is at
and authentication is via our LDAP.
I'm going to try installing a node exporter on tracsvn next.
Attached is a sample chart in Grafana for nexus container
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2449>
OSGeo <https://osgeo.org/>
