#2453: can not login using LDAP to osgeo webpage
Reporter: codrina | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
I can't login using LDAP (userID codrina) to the OSGeo website. After
resetting the password, it still doesn't work. The error I get is wrong
credentials, however I have no problem using those to login into
nextcloud, gitea or trac. I know that at some point, long ago, I could
login. I did some editing before the website was public, so maybe my
account was not made using LDAP.
Any help will be much appreciated.
Codrina
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2453>
OSGeo <https://osgeo.org/>
Priority: normal | Milestone: Sysadmin Contract 2020-I
Component: Systems Admin | Resolution:
Keywords: |
Changes (by strk):
* milestone: Unplanned => Sysadmin Contract 2020-I
Comment:
If you can login into Gitea and Trac then YES, your account made it into
LDAP.
If Website doesn't let you, it must be a Website issue.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2453#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
* milestone: Sysadmin Contract 2020-I => Unplanned
Comment:
codrina -- your account was created locally I think and was missing the
LDAP bits.
I merged your ldap and local account so you should be able to log in now.
Did it from the database backend
INSERT INTO <wp prefix goes here>_usermeta(user_id, meta_key,meta_value)
VALUES (57, 'wpDirAuthFlag', 1)
,(57, 'wpdirauth_prnd', 1);
Please try logging in again to confirm it works, and feel free to reopen
if it doesn't.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2453#comment:2>
Keywords: |
Comment (by strk):
How could she connect to Trac and Gitea if the
account was only local ?
Can we DISABLE creation of "local" accounts on
the website ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2453#comment:3>
Keywords: |
Comment (by codrina):
Replying to [comment:2 robe]:
if it doesn't.
I tried it and it works! I can now successfully login into Trac, Gitea,
Nextcloud and OSGeo website. Thank you!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2453#comment:4>
