#2484: FOSS4G 2021 domain
Reporter: mlibman | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
We need the 2021.foss4g.org subdomain to point to our website
We have our website up and running at https://foss4g-2021.gitlab.io/
Because it's a GitLab page, we need[1]:
- A DNS A or CNAME record pointing 2021.foss4g.org to GitLab Pages server.
- A DNS TXT record to verify the domain’s ownership
For the last part you will need a token, that I can generate once I know
you will use it, as it expires.
[1]https://docs.gitlab.com/ee/user/project/pages/custom_domains_ssl_tls_certification
/#set-up-pages-with-a-custom-domain
Thanks!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2484>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by wildintellect):
I've added the CNAME record per Gitlab's subdomain instructions. Go ahead
send me the TXT challenge info directly, or add me to the gitlab
project(wildintellect on gitlab.com) I'll put it in.
Thanks - Alex
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2484#comment:1>
Keywords: |
Comment (by mlibman):
Hi Alex, I just added you to the Gitlab Project
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2484#comment:2>
Keywords: |
I'm in, but I think I need more permissions to see the settings.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2484#comment:3>
Keywords: |
Oh! sorry, check now please
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2484#comment:4>
Keywords: |
Ok HTTP is enabled, HTTPS should propagate in a few minutes. Will check
back later today, and close this ticket when confirmed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2484#comment:5>
Keywords: |
Didn't do the TXT record right the 1st time. Got it now. Domain is
verified.
"GitLab is obtaining a Let's Encrypt SSL certificate for this domain. This
process can take some time. Please try again later."
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2484#comment:6>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by wildintellect):
* status: new => closed
* resolution: => fixed
Comment:
https://2021.foss4g.org/ works. Closing.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2484#comment:7>
