#2485: Switch grass.osgeo.org to osgeo7
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2020-I
Component: Systems Admin | Keywords:
Markus said he's ready to go live with staging.grass.osgeo.org
So going to do the switch now
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2485>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Done
https://git.osgeo.org/gitea/sac/osgeo7/commit/36ea13c77378b23cfe0a116307cf581b73ce4bc6
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2485#comment:1>
Keywords: |
Comment (by robe):
For completeness - deregistered grass.osgeo.org ssl on osgeo6 with this
command
which seemed to have also upgraded certbot-auto (hopefully won't cause
issues)
root@osgeo6:~# certbot-auto delete
Upgrading certbot-auto 1.5.0 to 1.6.0...
Replacing certbot-auto...
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Which certificate(s) would you like to delete?
1: docs.geotools.org
2: geos.osgeo.org
3: geotools.org
4: grass.osgeo.org
5: grasswiki.osgeo.org
6: lists.osgeo.org
7: mapserver.org
8: osgeo6.osgeo.osuosl.org
Select the appropriate numbers separated by commas and/or spaces, or leave
input
blank to select all options shown (Enter 'c' to cancel): 4
Deleted all files relating to certificate grass.osgeo.org.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2485#comment:2>
Keywords: |
Comment (by neteler):
Big thank you for your support, @robe!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2485#comment:3>
