#2498: deegree maven repository
Reporter: Tfr42 | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
The deegree project would like to publish it's build and release artifacts
on the OSGeo Nexus Maven repository.
And is asking for access rights to upload artifacts using the project's
Jenkins build server.
See issue https://github.com/deegree/deegree3/issues/1075 for further
information
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2498>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Torsten since you have been approved for SAC membership I have made you an
admin of the repo.osgeo.org nexus instance.
You should be able to create degree project now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2498#comment:1>
Keywords: |
Comment (by robe):
I also added you to the shell group and also gave you admin rights to the
nexus container on osgeo3 where repo.osgeo.org resides in case you need
filesystem access.
In order to access these - you'll need to register your ssh keys and also
setup yourself as detailed in
https://wiki.osgeo.org/wiki/SAC_Service_Status#sshing_into_osgeo3_containers
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2498#comment:2>
Keywords: |
Comment (by Tfr42):
Ok, thank you. Access to gitea and nexus admin UI works.
Is there any further documentation available about naming conventions of
hosted repositories and their configuration?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2498#comment:3>
Keywords: |
Comment (by robe):
Yes Jody did establish naming conventions which are described in below
link
https://wiki.osgeo.org/wiki/SAC:Repo#Repositories
This was my attempt at explaining the docker setup and basic naming:
https://wiki.osgeo.org/wiki/SAC:Repo#Docker_Instructions_for_OSGeo_Projects_Teams
Feel free to amend that if you see any errors are things you'd like
changed (now that you are a repo admin
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2498#comment:4>
Keywords: |
Comment (by jive):
Please ask me any questions, would like to keep things consistent.
Note we are having some trouble managing snapshots at present (there are
two different mechanisms and we found that setting up a task for each
snapshot repository worked)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2498#comment:5>
Keywords: |
Comment (by jive):
Okay the trouble managing snapshot clean has been resolved, was being a
bit too aggressive cleaning them up.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2498#comment:6>
