#2502: repo.osgeo.org snapshot management problems reported
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
We are having a number of failed builds from individual developers and
build automations (github actions, taavis0 making use of the osgeo
snapshot repository.
So far these are hard to reproduce in isolation, so an experimental pull
request has been setup here:
https://github.com/geoserver/geoserver/pull/4461
As an example of a specific failure:
> DEBUG] Could not find metadata org.geotools:gt-main:24-SNAPSHOT/maven-
metadata.xml in local (/home/travis/.m2/repository)
Builds were also failing on gwc, but checking the build logs we can see
these being uploaded:
> Uploading to nexus: https://repo.osgeo.org/repository/geoserver-
snapshots/org/geowebcache/gwc-web/1.18-SNAPSHOT/gwc-
web-1.18-20200824.192934-1.jar
Checking the repo logs I have not yet seen these jars being removed:
> 2020-08-24 19:32:19,744+0000 INFO [quartz-7-thread-20] *SYSTEM
org.sonatype.nexus.repository.maven.internal.orient.RemoveSnapshotsFacetImpl
- Elapsed time: 1.840 s, deleted 0 components from 0 distinct GAVs
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by aaime):
Important note, it's not the jar that goes missing, it's the maven-
metadata.xml file that does.
When working with snapshots, maven creates a timestamped directory and
jars within, the maven-metadata.xml file tells clients how to go from
"SNAPSHOT" to the actual pom and jar files. The maven-metadata.xml seems
to be correctly uploaded, but after some time, it disappears. Without it,
the clients don't know how to get to the jar and report it missing.
See more details here:
https://github.com/geoserver/geoserver/pull/4461#issuecomment-679257784
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:1>
Keywords: |
Changes (by robe):
* Attachment "maven_cleanup_policy.png" added.
Keywords: |
Comment (by robe):
One thought -- could it be the cleanup policy jobs we have in place at
fault here? Maybe we can disable them to see if things get better or
increase longevity.
For example the cleanup policy I see has:
[[Image(maven_cleanup_policy.png)]]
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:2>
Keywords: |
Comment (by robe):
ignore my last comment. I see that was brought up on
jive - so it sounds like you maybe have fixed this issue? Are you waiting
to see if it is truly fixed before closing this or are there still
outstanding problems?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:3>
Keywords: |
Comment (by jive):
I may of fixed the issue, some of the clean up tasks run daily so I wanted
to give them a chance to work.
I left the "repair" tasks define and available to run manually if we ever
have trouble with maven-metadata.xml files again.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:4>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by jive):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:5>
Keywords: |
Comment (by robe):
jive in reviewing whether it's time to upgrade repo.osgeo.org, I came
across this bug that affects 3.26.0, 3.25.1, 3.26.1 that is fixed in 3.27.
It sounds an awful lot like what you were all experiencing.
https://issues.sonatype.org/browse/NEXUS-24988
Is it the same -- if so maybe I should upgrade our version to latest
micro. We are currently running 3.25.1.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:6>
Type: task | Status: reopened
Keywords: |
Changes (by jive):
* status: closed => reopened
* resolution: fixed =>
Comment:
This problem is persisting, and is getting quite frustrating with many
downstream projects affected (for example unable to download gt-
main-25-SNAPSHOT)
I presently cannot tell if the issue is:
a) either concurrent builds on build.geoserver.org both deploying to the
same geotools repository.
b) or the nexus cleanup activities here producing a corrupt maven-
metadata.xml files (which a manual run of a repair maven-metadata.xml
activity fixes).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:7>
Keywords: |
Comment (by jive):
Q from Andrea:
> Does repo.osgeo.org have any form of safety, like rate limiting and the
like,that might trigger when the multiple builds we have all start in
parallel and download jars from the repo?It could be in the repo manager,
but also in whatever is fronting it on its way to the internet.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:8>
Keywords: |
Comment (by jive):
Replying to [comment:6 robe]:
Please let's try it!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:9>
Keywords: |
Comment (by jive):
Passing message on from Andrea:
> "robe" comment two weeks ago seems to be spot on, an upgrade might be
solving our issues?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:10>
Reporter: jive | Owner: robe
Priority: major | Milestone: Unplanned
Keywords: |
Changes (by jive):
* owner: sac@… => robe
* priority: normal => major
* status: reopened => new
Comment:
robe I am increasing the priority (as this is effecting so many people)
and passing the task to you with respect to upgrading nexus.
Thank you for hunting down NEXUS-24988 issue it really sounds like our
problem.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:11>
Keywords: |
Comment (by robe):
I'll upgrade this later tonight and let you know once done. The upgrade
generally takes about 5 minutes. Is it okay for me to go ahead later
tonight or do I need to notify folks?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:12>
Keywords: |
Comment (by jive):
Please just update, I am looking forward to seeing this fixed. Thanks for
much for finding it was a bug, and not just a mistake I made with setup.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:13>
Keywords: |
Comment (by robe):
okay I will start the upgrade now and close this out once done.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:14>
Keywords: |
Changes (by robe):
Comment:
Done with upgrade to 3.27.0-03. For future reference this is how I
upgrade nexus.
Replace robe with your ldap account - sudoers are: robe,jive,tfr42
ssh robe@osgeo3-nexus
sudo -i
sh nexus.sh
docker ps #confirm docker container has restarted
After that it does some internal upgrade stuff so repo.osgeo.org shows
"Bad Gateway"
Don't panic. I repeat DO NOT PANIC.
It takes about 5 minutes for the docker container to be fully functional.
Don't panic, just be patient. In about 5 minutes after startup you should
be able to go to
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:15>
Keywords: |
Comment (by jive):
Great I will turn off my workarounds and we will see if the bug is fixed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2502#comment:16>
