#2515: certificate has expired
Reporter: cvvergara | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
When testing some links for the OSGeoLive project the following came out
https://download.osgeo.org/gdal/workshop/foss4ge2015/workshop_gdal.html -
HTTPSConnectionPool(host='download.osgeo.org', port=443): Max retries
exceeded with url: /gdal/workshop/foss4ge2015/workshop_gdal.html (Caused
by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED]
certificate verify failed: certificate has expired (_ssl.c:1123)')))
at:
https://github.com/OSGeo/OSGeoLive-
doc/pull/627/checks?check_run_id=1203123581#step:9:1060
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2515>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by cvvergara):
I am re-running the test, as maybe that PR to OSGeoLive was done before
the recent renewal
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2515#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: invalid
Keywords: |
Changes (by cvvergara):
* status: new => closed
* resolution: => invalid
Comment:
Results of that test re-run, came ok
doc/pull/627/checks?check_run_id=1216934409
Closing as the certificate was renewed after that PR.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2515#comment:2>
