#2521: Change secure to use dedicated cert and set up script to copy the cert
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
secure right now is using a letsencrypt wildcard cert which I never got
around to changing to a ldap.osgeo.org cert. So I've been renewing it
every 3 months which is not ideal.
My proposed:
Change to use ldap.osgeo.org
Setup a script on nginx that when it renews it copies the script to secure
container.
I do have a script already that copies the cert but it can be improved to
not require manual stuff. Something a savyor network admin like strk can
do inhis sleep.
I have what I am currently doing outlined here
https://git.osgeo.org/gitea/sac/osgeo7/wiki/NGinx-Proxy-container#user-
content-generating-wildcard-cert-for-osgeo-org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521>
OSGeo <https://osgeo.org/>
Priority: normal | Milestone: Sysadmin Contract 2020-II
Component: Systems Admin | Resolution:
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2020-II
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:1>
Keywords: |
Comment (by strk):
I'm a bit confused by this ticket.
According to https://wiki.osgeo.org/wiki/SAC_Service_Status#NGINX_proxy
the nginx container proxies all traffic, then why should the cert be
installed in the underlying container ? Is ldap.osgeo.org out of the proxy
? What makes ldap.osgeo.org different from other containers ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:2>
Keywords: |
Comment (by strk):
Answering myself: LDAP is different in that it's NOT using the certificate
in a web server but a LDAP server. We could have nginx indeed respond to
http requests for the LDAP server IP address for the sole purpose of doing
http validation for letsencrypt. About the copy I wonder if we should be
instead MOUNTING the certificate directory directly, instead of copying it
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:3>
Keywords: |
Comment (by robe):
Mounting sounds like a cleaner approach. Only issue with that is it makes
it less portable.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:4>
Keywords: |
Comment (by strk):
The cronjob should be written in the new ansible deployment playbooks:
https://git.osgeo.org/gitea/sac/ansible-deployment
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:6>
Keywords: |
Comment (by strk):
Cron job is now in place and deployed via ansible. It has to be tested
that it works correctly, including when errors arise, as I'm not sure if a
mail would ever be received on error (no MTA on osgeo7?)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:7>
Keywords: |
Comment (by strk):
Cron mails will arrive, as per #2536 - now it's to be tested if those
mails are too noisy, and then if renewal is effective.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:8>
Keywords: |
Comment (by strk):
I've added the ldap.osgeo.org virtual host configuration to the ansible
deployment repository with https://git.osgeo.org/gitea/sac/ansible-
deployment/commit/971e9a6fa5661353337f39194557644ac1609b54
Didn't add more virtual hosts but we should, in a separate ticket.
Only things left out of ansible yet is:
- certbot configuration for ldap.osgeo.org
- LXC container configuration to ensure a device listening on
ldap.osgeo.org is added to the 'nginx container
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:9>
Keywords: |
Comment (by strk):
nginx container setup was added to ansible playbooks with
deployment/commit/711a269093b1bb460a7180c5f5d39e2d6ade48fb
Only thin left out of ansible is now certbot configuration for
ldap.osgeo.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:10>
Keywords: |
Changes (by strk):
* milestone: Sysadmin Contract 2020-III => Sysadmin Contract 2020-II
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:12>
Priority: normal | Milestone: Sysadmin Contract 2021-II
Keywords: |
Changes (by robe):
* milestone: Sysadmin Contract 2020-II => Sysadmin Contract 2021-II
Comment:
Okay this is till not working so reopening it.
When I do this:
Check if secure's cert expire date
openssl s_client -servername ldap.osgeo.org -connect ldap.osgeo.org:636
2>/dev/null | openssl x509 -noout -dates
I get:
notBefore=Sep 29 09:16:39 2021 GMT
notAfter=Dec 28 09:16:38 2021 GMT
When I check the recently received cert on nginx:
openssl s_client -servername ldap.osgeo.org -connect ldap.osgeo.org:443
I get
notBefore=Nov 28 19:31:56 2021 GMT
notAfter=Feb 26 19:31:55 2022 GMT
If I restart slapd on osgeo7-secure
systemctl restart slapd
It does not fix the issue.
So it seems the cronjob is not working.
The cronjob on osgeo7 looks
sudo systemctl status cron
shows this:
Dec 05 12:30:01 osgeo7 CRON[25890]: (tech_dev) CMD
(/usr/local/bin/copy_ldap_certs_to_secure.sh)
Dec 05 12:30:01 osgeo7 cron[4341]: sendmail: fatal: open
/etc/postfix/main.cf: Permission denied
Dec 05 12:30:01 osgeo7 CRON[25889]: (tech_dev) MAIL (mailed 109 bytes of
output but got status 0x004b from MTA
Dec 05 12:30:01 osgeo7 CRON[25889]: pam_unix(cron:session): session closed
for user tech_dev
Dec 05 13:17:01 osgeo7 CRON[7005]: pam_unix(cron:session): session opened
for user root by (uid=0)
Dec 05 13:17:01 osgeo7 CRON[7009]: (root) CMD ( cd / && run-parts
--report /etc/cron.hourly)
Dec 05 13:17:01 osgeo7 CRON[7005]: pam_unix(cron:session): session closed
for user root
Dec 05 14:17:01 osgeo7 CRON[18083]: pam_unix(cron:session): session opened
Dec 05 14:17:01 osgeo7 CRON[18084]: (root) CMD ( cd / && run-parts
Dec 05 14:17:01 osgeo7 CRON[18083]: pam_unix(cron:session): session closed
for user root
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:13>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
okay looks like a permission issue.
I can't run under the osgeo7 tech_dev account
Get this
Error: open /var/lib/snapd/hostfs/etc/cron.d/fullchain.pem.new: permission
denied
tech_dev@osgeo7:/etc/cron.d$ sudo
fullchain.pem.new fullchain.pem.current differ: byte 34, line 2
But if I do
sudo /usr/local/bin/copy_ldap_certs_to_secure.sh
It works. I'm gong to change the cronjob to do sudo.
strk feel free to change again if you don't feel that is right.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2521#comment:14>
