#2523: Wordpress down and backup failing on it
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: blocker | Milestone: Unplanned
Component: Systems Admin | Keywords:
The wordpress container last nights backup failed with a
: zfs mount osgeo7/containers/wordpress: cannot mount
'osgeo7/containers/wordpress': filesystem already mounted
I just tried rebooting the container to see if that would fix the issue
but it now refuses to come back up.
This means osgeo.org website is down at moment.
osgeo7 has been asking for a reboot for quite sometime so if all fails I
will do that shortly.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2523>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I ended up having to reboot OSGeo7 to fix this issue as even
systemctl reload snap.lxd.daemon
or
systemctl restart snap.lxd.daemon
Did not fix the issue.
For some reason some containers did not start back on their own so I ended
up manually restarting them
Ones I had to manually restart
download
grass
nextcloud-ubuntu
nginx
old-projects
secure
wordpress
oddly enough none of the containers with docker installed needed a manual
start. Not sure if there is significance to that or not.
Regarding the note from info@osgeo.org about wordpress running out of disk
space. It had plenty of disk space, but I suspect the issue with the
mount might have triggered a low disk space error. So I don't think that
was a fake message.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2523#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Also forgot to mention old-adhoc did not start back on it's own. Still
need to get all stuff off of that.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2523#comment:2>
