#2533: Set up debian10 for grasswiki
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
grasswiki is still on osgeo6 and eventually we will rebuild osgeo6. So
makes sense to containerize this.
It looks like grasswiki uses drupal and MySQL.
So I assume we can throw in debian10, latest MariaDB, PHP 7.4, and drupal
and restore grasswiki files and backup on that.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533>
OSGeo <https://osgeo.org/>
Priority: normal | Milestone: Sysadmin Contract 2020-III
Component: Systems Admin | Resolution:
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2020-III
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:1>
Keywords: Mediawiki, lxd |
Changes (by neteler):
* cc: martinl (added)
* keywords: => Mediawiki, lxd
Comment:
Indeed grasswiki uses Mediawiki ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
https://grasswiki.osgeo.org/wiki/Special:Version
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:2>
Comment (by robe):
ah sorry not sure why I thought it was drupal. So we can configure it
much the same as we did with the new wiki.osgeo.org -
https://wiki.osgeo.org/wiki/SAC_Service_Status#wiki
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:3>
#2533: Set up debian11 for grasswiki
Priority: normal | Milestone: Sysadmin Contract 2021-II
Comment (by robe):
I did start setting this up and upgraded to debian 11. Still need to pull
over the data from osgeo6.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:6>
Comment (by neteler):
Thanks!
A question: grasswiki uses some Mediawiki extensions are not part of
wiki.osgeo.org, is that an issue?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:7>
Comment (by robe):
It's on osgeo3 but in a separate container from wiki.osgeo.org, so not an
issue at all.
I did start off with an image of wiki.osgeo.org and dropped all the data
and started copying over grasswiki stuff - detailed here -
https://git.osgeo.org/gitea/sac/osgeo3/wiki/grass-wiki-IN-PROGRESS
But then got side tracked with other things. I'm hoping to upgrade it to
debian 11 (bullseye) this week and finish restoring the wiki database and
files, and try to upgrade to latest media-wiki.
If you want to try logging in, the server is on osgeo3 and called grass-
wiki. I gave you sudo access
https://wiki.osgeo.org/wiki/SAC_Service_Status#osgeo3
ssh neteler@osgeo3-grass-wiki
should get you in.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:8>
Description changed by robe:
Old description:
New description:
It looks like grasswiki uses wiki (wikimedia) and MySQL.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:9>
Thanks for your efforts, @robe!
I tried to login but it still asks for a pw:
(neteler@osgeo3-grass-wiki) Password:
Extra wish: could you please also enable Martin Landa? (he installed it
the grasswiki on osgeo6)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:10>
Comment (by robe):
Just type in your ldap password. I don't have ssh public keys check on
the containers by default and have password access allowed (since they are
protected from direct ssh anyway) I figured owners might want to lock
them down. You can install your key after you log in first time.
You should be able to add Martin as sudo or let me know his username.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:11>
Comment (by robe):
FYI running into a little issue with restoring the mysql db.
Getting this error:
ERROR 1062 (23000) at line 393: Duplicate entry '4140' for key 'PRIMARY'
Looking at the number of tables restored:
with this query:
-- I have 11 tables restored
SELECT table_name, table_rows
FROM INFORMATION_SCHEMA.TABLES
WHERE TABLE_SCHEMA = 'grass_wiki'
ORDER BY table_name;
-- but osgeo6 has 58 rows
I suspect it crapped out at the hit_counter table since osgeo6 has 2943
rows and the restore has 0 for that table. I'm checking that table on
osgeo6 to see if it has dupes.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:12>
Comment (by robe):
I see the record in the hit_counter table with page_id = 4140, but does
not appear duplicated in osgeo6
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:13>
Comment (by robe):
Okay resolved the issue. Must have been some sort of fragmentationin the
hit_counter table.
Doing:
use grass_wiki;
optimize table hit_counter;
and then redoing the backup and restore fixed the issue. So now counts
look about the same in each database.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:14>
Replying to [comment:11 robe]:
Works, thanks.
This is his account:
https://id.osgeo.org/ldap/search?query=martinl
Glad you got the DB mess fixed!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:15>
Comment (by robe):
Okay martinl should be set to. I'm going to next create a
staging.grasswiki.osgeo.org to point to this so we can do a final pass
thru after I reset up and try to upgrade it to latest wiki. Then once we
feel comfortable we can reload and do the repoint.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:16>
Comment (by robe):
I have https://staging.grasswiki.osgeo.org up but trying to troubleshoot
why none of the pages are showing content. I haven't upgraded wikimedia
yet.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:17>
Comment (by robe):
One of the causes of blank pages is the pcre changes
https://www.mediawiki.org/wiki/Manual:Common_errors_and_symptoms#All_pages_have_no_content,_but_when_editing_a_page_the_wiki_text_is_there.
On osgeo6 we have php 7.0 and on new grass-wiki is running php 7.3, so I
guess this means I have to upgrade before I can confirm things are
working. As the version of mediawiki is 1.27.1 and latest stable is 1.37.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:18>
Comment (by robe):
Okay upgrading it to latest wikimedia (1.37.1) version made the pages
reappear again. I had to put in the latest versions of the extensions and
change most extensions except for the Polyglot one to the new standard
wfLoadExtension( 'Pluinname' ); syntax. I still want to upgrade it to
bullseye to make sure that works okay.
Please take a look when you have the chance.
If all looks good I'll do a final cutover the of the user files and
another snapshot of the db and upgrade of the database and repoint the
domain. (I also needed to change the LocalSettings to have $wgServer =
"https://staging.grasswiki.osgeo.org"; so will need to change that when we
go live.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:19>
Priority: normal | Milestone: Sysadmin Contract 2022-I
There is still an error:
Error creating thumbnail: Unable to save thumbnail to destination
in several places. Would you mind to check the permissions?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:21>
Comment (by robe):
Okay will do. I still need to upgrade it too to debian11. Will do in a
bit.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2533#comment:22>
