#2542: Revise the way SSH keys are stored in LDAP
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2020-II
Component: Systems Admin | Keywords: LDAP
We are probably doing it wrong by allowing multiple keys in a single
attribute.
See https://github.com/go-gitea/gitea/issues/13984#issuecomment-744494376
Ticket #2116 was about adding the LDAP attribute
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2542>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: LDAP |
Comment (by strk):
Revision seems needed for #2457 completion (use keys with Gitea)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2542#comment:1>
Keywords: LDAP |
Comment (by strk):
We're definitely doing this wrong: https://github.com/go-
gitea/gitea/issues/13984#issuecomment-749275922
We'd want each ssh key to be a different element of an array stored in the
attribute, and UI to add/remove elements in that array.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2542#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: LDAP |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
This is now fixed with https://git.osgeo.org/gitea/sac/web-cgi-
bin/commit/02550ef08792a2615d170d883e3683f5cedce431
We'll store ssh keys as multiple ones (separated by newlines in the
textarea)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2542#comment:3>
