#2545: download osgeo org quota
Reporter: darkblueb | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
recently downloading the OSGeoLive night build (4GB iso), I noticed that
there is a precise `1.01 GB` limit of some kind, where the download
connection is interrupted. Using `wget -c` auto-retries and reconnects
without manual steps, so far.
$ wget -c --limit-rate=333k https://download.osgeo.org/livedvd/nightly
/osgeolive-nightly-build160-amd64-8574817-master.iso
--2020-12-15 13:36:10-- https://download.osgeo.org/livedvd/nightly
Resolving download.osgeo.org (download.osgeo.org)... 140.211.15.30
Connecting to download.osgeo.org
(download.osgeo.org)|140.211.15.30|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 4352638976 (4.1G) [application/octet-stream]
Saving to: ‘osgeolive-nightly-build160-amd64-8574817-master.iso’
osgeolive-nightly-build160-am 24%[==========>
] 1.01G 346KB/s in 57m 5s
2020-12-15 14:33:15 (308 KB/s) - Connection closed at byte 1081786547.
Retrying.
--2020-12-15 14:33:16-- (try: 2)
https://download.osgeo.org/livedvd/nightly/osgeolive-nightly-
HTTP request sent, awaiting response... 206 Partial Content
Length: 4352638976 (4.1G), 3270852429 (3.0G) remaining [application/octet-
stream]
osgeolive-nightly-build160-am 49%[+++++++++++===========>
] 2.02G 341KB/s in 54m 23s
2020-12-15 15:27:40 (324 KB/s) - Connection closed at byte 2165720864.
Retrying.
--2020-12-15 15:27:42-- (try: 3)
Length: 4352638976 (4.1G), 2186918112 (2.0G) remaining [application/octet-
stream]
osgeolive-nightly-build160-am 74%[+++++++++++++++++++++++===========>
] 3.03G 342KB/s in 52m 59s
2020-12-15 16:20:41 (333 KB/s) - Connection closed at byte 3249611664.
Retrying.
--2020-12-15 16:20:44-- (try: 4)
Length: 4352638976 (4.1G), 1103027312 (1.0G) remaining [application/octet-
stream]
99%[+++++++++++++++++++++++++++++++++++===========> ] 4.03G 343KB/s
in 52m 55s
2020-12-15 17:13:39 (333 KB/s) - Connection closed at byte 4331931552.
Retrying.
--2020-12-15 17:13:43-- (try: 5)
Length: 4352638976 (4.1G), 20707424 (20M) remaining [application/octet-
stream]
100%[+++++++++++++++++++++++++++++++++++++++++++++++>] 4.05G 347KB/s
in 61s
2020-12-15 17:14:44 (334 KB/s) - ‘osgeolive-nightly-
build160-amd64-8574817-master.iso’ saved [4352638976/4352638976]
------(the next day ed.)----------------------------------
dbb@HOST:/home/shared/OSGEO$ wget -c
http://download.osgeo.org/livedvd/releases/14.0/osgeolive-14.0alpha3-amd64.iso
--2020-12-19 07:18:13--
Connecting to download.osgeo.org (download.osgeo.org)|140.211.15.30|:80...
connected.
Length: 4285530112 (4.0G) [application/octet-stream]
Saving to: ‘osgeolive-14.0alpha3-amd64.iso’
osgeolive-14.0alpha3-amd64.is 25%[===========>
] 1.01G 370KB/s in 48m 25s
2020-12-19 08:06:39 (364 KB/s) - Connection closed at byte 1083829064.
Retrying.
--2020-12-19 08:06:40-- (try: 2)
connected.
Length: 4285530112 (4.0G), 3201701048 (3.0G) remaining [application/octet-
stream]
osgeolive-14.0alpha3-amd64.is 40%[++++++++++++======>
] 1.61G 370KB/s eta 1h 53m ^C
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2545>
OSGeo <https://osgeo.org/>
