#2573: Access to nexus docker repository for geoserver image
Reporter: Buehner | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
We would like to publish official docker images for the geoserver. In
https://github.com/geoserver/docker/pull/1#issuecomment-796821135 Jody
Garnett pointed me to an osgeo docker repo for test stuff:
https://repo.osgeo.org/#browse/browse:geoserver-docker
But when i am logged in on the nexus with my account (buehner), i am
currently not able to access the mentioned repository.
After writing on the geoserver dev mailing list, Sandro Santilli suggested
to create a ticket here to get sufficient rights.
So it would be great if you could give me (buehner) the sufficient rights
to create/upload docker test images to the repository mentioned above.
Best regards,
Nils Bühner
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2573>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by jive):
Hello Nils, let me double check your nexus access. I was able to locate
your ldap user (osgeo id) but you had indeed not yet been added to nexus.
I have set you up with:
- GeoServer Administrator - to publish to geoserver repositories including
docker
- nx-anonymous - to see everything else
Please let me know if this worked.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2573#comment:1>
Reporter: Buehner | Owner: jive
Keywords: |
Changes (by jive):
* owner: sac@… => jive
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2573#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by jive):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2573#comment:3>
