#2577: Change domains using wildcard osgeo to single certs
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2021-I
Component: Systems Admin | Keywords:
Just took care of planet.osgeo.org
Others with same issue on osgeo7 nginx container
mapguide.osgeo.org - fixed
rewrite contains several but they are all written as permanent redirects
so not sure they are worth fixing since the worst that will happen is a
warning and the non-https redirect still wors
osgeo4w.osgeo.org -> https://trac.osgeo.org/osgeo4w/
geotools.osgeo.org -> https://www.osgeo.org/geotools
proj4j.osgeo.org -> https://trac.osgeo.org/proj4j
geotiff.osgeo.org -> https://github.com/OSGeo/libgeotiff
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2577>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Description changed by robe:
Old description:
New description:
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2577#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
this was also done
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2577#comment:2>
