#2580: tracsvn updates and high cpu utilization
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2021-I
Component: Systems Admin | Keywords:
Seems that tracsvn cpu went to 100% for the past 2 hours according to
monitor charts. Most of it was apache. At anyrate to rule out corrupt
memory etc, I took the time to run patch updates and restart.
Building dependency tree
Reading state information... Done
Calculating upgrade... The following packages were automatically installed
and are no longer required:
javascript-common libalgorithm-c3-perl libarchive-extract-perl libaudio2
libfftw3-double3 libfile-homedir-perl libharfbuzz-icu0 libintl-perl
libjs-jquery libjs-jquery-ui liblog-message-perl liblog-message-simple-
perl liblua5.1-0 libmodule-pluggable-perl libmodule-signature-perl
libopenjpeg5 libpackage-constants-perl libpod-latex-perl libpod-readme-
perl libpotrace0 libqt4-xml libqtcore4 libregexp-common-perl
libsub-install-perl libsynctex1 libterm-ui-perl libtext-template-perl
libvpx1 libwebp5 libwebpdemux1 libwebpmux1 libyaml-tiny-perl libzzip-0-13
linux-image-3.2.0-0.bpo.4-amd64 python-mock qtcore4-l10n rename
Use 'apt-get autoremove' to remove them.
Done
The following NEW packages will be installed:
javascript-common libarchive-extract-perl libfile-homedir-perl
libharfbuzz-icu0 libintl-perl libjs-jquery libjs-jquery-ui liblog-message-
perl
liblog-message-simple-perl libmodule-pluggable-perl libpackage-
constants-perl libpod-latex-perl libpotrace0 libsynctex1 libterm-ui-perl
libyaml-tiny-perl libzzip-0-13 postgresql python-mock python-nose rename
The following packages have been kept back:
apache2 apache2-mpm-prefork apache2.2-bin apache2.2-common blt console-
common debconf debconf-i18n dvipng ghostscript init-system-helpers
latex-beamer latex-xcolor libalgorithm-diff-xs-perl libapache2-mod-
evasive libapache2-mod-perl2 libapache2-mod-python libapache2-mod-svn
libapt-pkg-perl libbsd-resource-perl libclone-perl libcrypt-ssleay-perl
libcups2 libcupsimage2 libfcgi-perl libfile-fcntllock-perl
libfile-fnmatch-perl libfont-freetype-perl libgdk-pixbuf2.0-0 libgdk-
pixbuf2.0-common libgs9 libgs9-common libgtk2.0-0 libgtk2.0-bin
libhtml-parser-perl libio-pty-perl libio-socket-ssl-perl libjasper1
libkpathsea6 liblist-moreutils-perl liblocale-gettext-perl libm17n-0
libnet-dns-perl libnet-libidn-perl libnet-ssleay-perl libossp-uuid-perl
libpstoedit0c2a libptexenc1 libsocket6-perl libsub-name-perl libsvn-perl
libsvn1 libterm-readkey-perl libterm-size-perl libtext-charwidth-perl
libtext-iconv-perl libuuid-perl libxml-parser-perl libyaml-syck-perl
lmodern luatex perl perl-base perl-modules pgf preview-latex-style
python-gd python-matplotlib python-tk subversion tex-common texinfo
texlive
texlive-base texlive-binaries texlive-extra-utils texlive-font-utils
texlive-fonts-recommended texlive-fonts-recommended-doc
texlive-generic-recommended texlive-latex-base texlive-latex-base-doc
texlive-latex-extra texlive-latex-extra-doc texlive-latex-recommended
texlive-latex-recommended-doc texlive-luatex texlive-metapost texlive-
metapost-doc texlive-pictures texlive-pictures-doc texlive-pstricks
texlive-pstricks-doc
The following packages will be upgraded:
dpkg libee0 libept1.4.12 libpaper1 libpq5 libsystemd-login0
postgresql-10 postgresql-12 postgresql-client-10 postgresql-client-12
postgresql-client-common postgresql-common postgresql-contrib ssh
14 upgraded, 21 newly installed, 0 to remove and 93 not upgraded.
2 not fully installed or removed.
Need to get 14.7 MB/19.5 MB of archives.
After this operation, 10.9 MB of additional disk space will be used.
At some point we will need to upgrade to apache 2.4 but I think a lot of
config changes need to be made to make it compatible so will save that for
another data.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2580>
OSGeo <https://osgeo.org/>
