#2582: Create ubuntu 20 base container
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2021-I
Component: Systems Admin | Keywords:
I think a lot of OSGeo folks feel more comfortable with Ubuntu than Debian
and also Ubuntu tends to have more modern stuff.
So though for stability I like debian, for bleeding edge, I prefer Ubuntu.
That said we really need an Ubuntu 20 image ready to go with OSGeo ldap-
ssh ready to go. Going to add that to our inventory of lxd images.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2582>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by wildintellect):
The alternate solution would be to write an Ansible role to handle the
LDAP setup, and make it work with Ubuntu and Debian (likely to work on
future versions too).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2582#comment:1>
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
This is done. called osgeo-ubuntu-20 and uses LDAP for ssh auth. The
script to create it is in ansible repo - https://git.osgeo.org/gitea/sac
/ansible-deployment/src/branch/master/deployment/roles/images/tasks/build-
osgeo-ubuntu-20.04.yml
I had to manually edit the description of image cause don't know how to do
that in ansible.
#one thing left is to have it use osuosl repos (which darkblueb already
changed on live)
I created the image on osgeo9. I'm using osgeo9 as an image store and
drone client, cause the disk size is too small to do much else with. I
used this image to create the live container on osgeo7 host
#lists images
lxc image list osgeo9:
#creates new container based on image osgeo-ubuntu-20 and calls the
container n20
lxc launch osgeo9:osgeo-ubuntu-20 n20
outputs:
| ALIAS | FINGERPRINT | PUBLIC |
DESCRIPTION | ARCHITECTURE | TYPE |
SIZE | UPLOAD DATE |
| hop | 18e74aa0a707 | no | Debian buster amd64
(20190106_05:25) | x86_64 |
CONTAINER | 269.00MB | Jun 28, 2021 at 9:27pm (UTC) |
| osgeo-debian-10 (1 more) | f32428620de4 | no | Debian buster amd64
(20190106_05:25) - Debian 10 with OSGeo LDAP SSH | x86_64 |
CONTAINER | 249.31MB | May 29, 2021 at 1:48am (UTC) |
| osgeo-debian-11 | a64bd7b1d088 | no | Debian buster amd64
(20190106_05:25) upgraded to Debian 11 OSGeo LDAP SSH | x86_64 |
CONTAINER | 280.48MB | Oct 3, 2021 at 3:27am (UTC) |
| osgeo-debian-11-docker | 6876eee33d83 | no | Debian bullseye amd64
with OSGeo LDAP + docker (2021-10-23) | x86_64 |
CONTAINER | 607.39MB | Oct 23, 2021 at 11:34pm (UTC) |
| osgeo-ubuntu-20 | 86b7088cd715 | no | Ubuntu 20.04 LTS
server with OSGeo LDAP SSH (20211004) | x86_64 |
CONTAINER | 529.15MB | Oct 8, 2021 at 4:56am (UTC) |
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2582#comment:3>
