#2590: OSgeo7 snapshot backups failing on some containers
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: critical | Milestone: Unplanned
Component: Systems Admin | Keywords:
Quite a few on osgeo7 the snapshotting has stopped working with that
error:
Error: Create instance snapshot (mount source): Failed to run: zfs mount
osgeo7/containers/mapserver: cannot mount 'osgeo7/containers/mapserver':
filesystem already mounted
When you do:
lxc snapshot mapserver
shutting down the server was preventing it from coming back too.
I'm going thru them now, I've fixed nextcloud-ubuntu and mapserver.
Manually running mount as follows
zfs mount osgeo7/containers/mapserver
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2590>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Description changed by robe:
Old description:
error:
When you do:
New description:
error:
When you do:
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2590#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Others needing manual intervention were:
download
dronie-server
secure
tracsvn
wordpress
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2590#comment:2>
