#2591: Buy new drives for osgeo9 and osgeo8
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
We have control over osgeo8 and osgeo9 (donated by OSMF) now.
The specs are as follows:
Both are HP ProLiant DL360 G6 servers
osgeo8 has me a little concerned in that one of the drive bays (drive bay
7 shows as faulty)
It has following specs
Drives:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 1.7T 0 disk
├─sda1 8:1 0 1M 0 part
├─sda2 8:2 0 488M 0 part /boot
└─sda3 8:3 0 1.7T 0 part
├─lvm-swap 253:0 0 1.9G 0 lvm [SWAP]
└─lvm-root 253:1 0 10G 0 lvm /
So this gives us I think 800GB storage after we consider ZFS mirroring
2 physical processors (Intel(R) Xeon(R) CPU X5660 @ 2.80GHz, 12288 KB
cache) - each with 12 cores it seems - cause reads 24 cpu from Ubuntu (but
shows 2 processors from KVM)
Internal L1 Cache: 192 KB
Internal L2 Cache: 1536 KB
Internal L3 Cache: 12288 KB
osgeo9 has the following specs
So I think we definitely should put in some new discs to make most of the
cpu and memory.
Drives:
sda 8:0 0 410G 0 disk
└─sda3 8:3 0 409.5G 0 part
So this gives us I think 200GB storage after we consider ZFS mirroring
2 physical Processors (Intel(R) Xeon(R) CPU X5660 @ 2.80GHz, 12288 KB
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Grant Slater and Lance from OSUOSL commented:
> > I see that on osgeo8 it shows drive bay 7 is faulty? Do you suggest
we do
> > something about that before we start using it?
> If you want to purchase and send us a replacement, we can get that taken
care of
> before you use it fully.
Model number of existing disks for reference:
HP EG0300FAWHV
G6 and G7 use the same disk caddies, but you can likely just reuse
existing.
Gen8+ machines use a newer caddy.
The disk has reasonable reliability and is available cheaply on ebay.
10K rpm disks are more reliable than 15K rpm disks.
Kind regards,
Grant
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:1>
Keywords: |
Comment (by robe):
I'd really like to move forward with this purchase. I've started to use
osgeo9 mostly for building images. I'm holding off using osgeo8 because
of the concern of the bad disk.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:2>
Keywords: |
Comment (by robe):
Thinking about this more, maybe we only need new drives for osgeo9, would
be nice if we could put some ssds in that one.
For osgeo8, as Angelos mentioned, there will be a need for vms dedicated
for ogc testing in cases where osgeo is the reference implementation
(things like various demo sites and also maybe a tutorial). For these
kinds of use cases, we need power, but if the disks go bad it's not as
critical since these will most likely be rebuilt by ci/cds. The other
thing is these kinds of use-cases would probably tend to wear down the
disks more so I'd rather get the last bit of life out of the ones we have.
That said osgeo8 has a good chunk of disk -- true I think one might be
bad, but maybe we should just wear it down, put non-mission critical stuff
on it. I also want to experiment with full VMS. Linux containers work
great for most things, but what they can't do is emulate hardware like the
arm platforms (something that a true VM can do). So this might be a good
place for those as well which would be dedicated to ci/cd testing.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:3>
Keywords: |
Comment (by wildintellect):
What size and quantity of disks do you propose for OSGeo9? What's the
intended use of OSGeo9?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:4>
Keywords: |
Comment (by robe):
For OSGeo9 it depends if we can put in SSDs or not. If SSDs then probably
best use of it for database intensivish stuff like wordpress (osgeo),
trac.osgeo.org (gitea), weblate (which I already have hosted on there )
but can easily move since it's containerized.
Without SSDs it would just provide more redundancy for OSGeo7 / OSGeo3 and
possibly set up a true failover system. But right now disk space of OSGeo9
is like 400GB so not enough to do much with.
https://wiki.osgeo.org/wiki/Osgeo9 (it too has 8 drivebays I think but
they are stuffed with much smaller drives than osgeo8). I think they
accept the same kind of drives though.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:5>
Keywords: |
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:6>
Priority: normal | Milestone: Sysadmin Contract 2022-II
Keywords: |
Changes (by robe):
* cc: wildintellect (added)
* milestone: Unplanned => Sysadmin Contract 2022-II
Comment:
I would like to get this done before my contract expires so I can put more
stuff on osgeo8 and osgeo9. Both these servers are slightly more powerful
than osgeo3.
Also eventually I'd want to rebuild osgeo7, which requires moving
everything to different server, but no server has enough disk space left
to fully accommodate osgeo7 instances.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:7>
Keywords: |
The same question stands from before, how many and which size disks are
being requested? Someone also needs to then look at some vendor options
and propose the purchase.
SSD seems possible but that might require that we also get brackets to
make them compatible with the caddies and slots?
Looks like we have $2500 in hardware budget, so the proposal would
preferably be less than that amount.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:8>
Keywords: |
Comment (by robe):
osgeo9 has 8 drives of product id - DH0072FAQRD ( DH0072FAQRD HP 72-GB 3G
15K 2.5 SP SAS ) that are all filled each with -73 GB 15 RPM disks.
osgeo8 also has 8 days all filled drives of EG0300FAWHV (HP EG0300FAWHV HP
300-GB 6G 10K 2.5 DP SAS) but 6 and 7 drives are showing as faulty.
The pricing on these drives are pretty cheap.
But I'd like something bigger than 300GB. I think disk space is more
important than SSD at this point. But I'll ask OSUOSL for their
recommendations.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:9>
Keywords: |
Comment (by pnorman):
I would strongly recommend against mechanical hard drives at this point
unless you need >> 10 TB space. SSDs involve less administrative work
because they fail much less often, and they're an order of magnitude
faster.
For our new servers we've tend to purchase them with enough disk space to
last the lifetime of the machine, so I haven't been involved in replacing
disks on them. Grant has, so you're better off asking him./
The two sensible options are new OEM disks, or used HP-branded disks.
The cheapest way to get 3TB usable per machine is 3x 1.92TB SSD in RAID5.
With your budget, you can afford to spend $416/drive.
For new SATA SSDs, it's about $400 per drive (Samsung PM883)
For used HP SATA or SAS SSDs, it's about $325 per drive.
This does seem like a lot to spend on HP DL360 G6 machines, which are only
worth about 100 bucks each.
For 2.5k you should be able to get a used HP DL360 Gen9 with a CPU
launched in 2016, 128GB RAM, and 3x1.92TB drives instead of a machine with
CPUs from 2010. The new machine would be far more powerful than the two
old machines combined.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:10>
Keywords: |
Comment (by darkblueb):
as a test setup
https://www.servermonkey.com/refurbished-hp-proliant-dl360-gen9-8-port-
configure-to-order.html
Selected Items:
HP ProLiant DL360 Gen9 8-Port Chassisx 1
Intel Xeon E5-2683 v3 Processor (2.0 GHz, 14C, 35MB Cache)x 2
16GB DDR4 RDIMM 2400MT/sx 12
HP H240 12Gb Smart Host Bus Adapterx 1
HP 960GB 6Gbps SATA 2.5" Solid State Drivex 3
RAID 5x 1
On-Board Quad Port 1GbE LOMx 1
No Additional Cardx 1
HPE Ethernet 366T Quad Port 1GbE Network Adapterx 1
No Optical Drivex 1
(2) HP G9 800 Watt PSUx 1
No Railsx 1
No Cable Management Armx 1
No Bezelx 1
iLo Standardx 1
No VMwarex 1
TekShield 8x5 Support with Replacement for 1 Yearx 1
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:11>
Keywords: |
Comment (by robe):
We are not buying another server this year. and I don't want to throw out
osgeo8 and osgeo9 cause they are more powerful than osgeo3 and osgeo4,
which have been lifesavers.
Plus there is additional headache of throwing out hardware. I also like
the idea of having 2 servers exactly the same so I can cluster them. I
can't do that with one server. We already have plenty of power. What we
lack is disk space capacity to match the amount of data currently on
osgeo7 so I can move instances to osgeo9 and osgeo8.
With that in mind, I'm leaning toward getting 10 disks HP EG0300FAWHV
300GB 10000RPM SAS 6GBPS DUAL PORT SFF 2.5INCH HARD DISK DRIVE
2 would go into osgeo8 (to replace the 2 faulty disks)
8 will replace all the disks in osgeo9
making the two servers equivalent.
Looking at - https://www.serversupply.com
{{{ Each disk is $44.00, so for 10 $440
Sub Total:
$440.00
Shipping:
$0.00
Tax(0.00%)
$0.00
Discount:
$4.40
Total:
$435.60
It would be nice to have maybe something that is 600GB, but I think if
osgeo9 had as much disk as osgeo8 we can live with that.
As Paul mentioned, probably not worth spending tons of money like $500/
SSD disk for these servers
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:12>
Keywords: |
Comment (by robe):
Oh ebay pricing for same:
https://www.ebay.com/itm/144589257532
This one we can get 10 for $330, so a bit better deal (28 remaining)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:13>
#2591: Buy new drives for osgeo8 and osgeo9
Keywords: |
Changes (by robe):
* summary: Buy new drives for osgeo9 => Buy new drives for osgeo8 and
osgeo9
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:14>
Keywords: |
Comment (by robe):
Scratch that, this one seems like a better deal, but would require
swapping out all the drives.
So would be a purchase of 16 drives.
https://www.ebay.com/itm/223605842312
600GB 10K SAS 2.5" 6Gb/s SERVER HARD DRIVE for HP DL360 DL380 DL385 G5 G6
G7
Cost per drive is $18*16 ~ $300 .
Giving us a raw 4.8 TB on each server to work with. Even at RAID 10, we
would get 2.4 TB usable on each.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:15>
Keywords: |
Comment (by msmitherdc):
Let me know when you finalize and I can purchase with the OSGeo cc.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:16>
Keywords: |
Comment (by robe):
This one is an SSD, and seems doable. For this might want to just put in
one of the servers and if we like buy 8 more. Or just use 4 drive bays on
each and split in two.
Or take a risk and buy 16.
https://www.ebay.com/itm/204064953402 ( Micron 1TB SATA SSD 2.5" 6GBPS
Hard Drive Fits HP DL360 DL380 DL385 G5 G6 G7 )
Since the size is 1TB per drive, we could maybe buy 8 ($60 / drive) = $480
If we go with 16 would be 16*60 = $960 (which would cover both servers).
These are cheaper cause they are refurbished and not HP brand, but I think
that's all fine. the servers are old so we don't need the drives to last
longer than the server and from reading reviews, none HP drives work just
as well in HP servers as HP drives
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:17>
Keywords: |
Comment (by robe):
Sadly I don't think SSDs are going to work since those require SATA and we
have SAS.
So safest is just stick with HDD SAS, but get larger size.
https://www.ebay.com/itm/224083213581
1.2TB 10K SAS 2.5" 6G Server Hard Drive for Fits HP DL360 DL380 DL385 G5
G6 G7
Cost: 4*$33 = $132
So planning to get 4 of these -- put 2 in osgeo8 to replace the 2 bad
drives, and 2 in osgeo 9 (swapping with 2 of the existing 70GB ones)
If these look good, then we can get 12 more = $396
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:18>
Keywords: |
Comment (by robe):
This was put for vote, motion passed -
https://lists.osgeo.org/pipermail/sac/2022-October/014711.html
4 drives have been purchased and onroute to OSUOSL. They are expected
there tomorrow.
In prep for upgrade, I am moving grass and weblate to osgeo7 today just in
case anything goes wrong and to minimize on downtime.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2591#comment:19>
