#2600: OSGEo4 host patch update 2021-05-10
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Keywords:
ok: [osgeo4] =>
output_apt_before_upgrade:
changed: true
diff: {}
failed: false
msg: |-
Reading package lists...
Building dependency tree...
Reading state information...
Calculating upgrade...
The following packages will be upgraded:
grub-common grub-pc grub-pc-bin grub2-common libnss-systemd
libpam-systemd
libsystemd0 libudev1 systemd systemd-sysv udev
11 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Inst libnss-systemd [237-3ubuntu10.46] (237-3ubuntu10.47
Ubuntu:18.04/bionic-updates [amd64])
Inst libsystemd0 [237-3ubuntu10.46] (237-3ubuntu10.47 Ubuntu:18.04
/bionic-updates [amd64]) [systemd:amd64 ]
Conf libsystemd0 (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates
Inst libpam-systemd [237-3ubuntu10.46] (237-3ubuntu10.47
Ubuntu:18.04/bionic-updates [amd64]) [systemd:amd64 ]
Inst systemd [237-3ubuntu10.46] (237-3ubuntu10.47 Ubuntu:18.04
Inst udev [237-3ubuntu10.46] (237-3ubuntu10.47 Ubuntu:18.04/bionic-
updates [amd64])
Inst libudev1 [237-3ubuntu10.46] (237-3ubuntu10.47 Ubuntu:18.04
Conf libudev1 (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates [amd64])
Conf systemd (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates [amd64])
Inst systemd-sysv [237-3ubuntu10.46] (237-3ubuntu10.47 Ubuntu:18.04
Inst grub-pc [2.02-2ubuntu8.21] (2.02-2ubuntu8.23 Ubuntu:18.04
Inst grub2-common [2.02-2ubuntu8.21] (2.02-2ubuntu8.23 Ubuntu:18.04
Inst grub-pc-bin [2.02-2ubuntu8.21] (2.02-2ubuntu8.23 Ubuntu:18.04
Inst grub-common [2.02-2ubuntu8.21] (2.02-2ubuntu8.23 Ubuntu:18.04
Conf libnss-systemd (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates
[amd64])
Conf libpam-systemd (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates
[amd64])
Conf udev (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates [amd64])
Conf systemd-sysv (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates
[amd64])
Conf grub-pc (2.02-2ubuntu8.23 Ubuntu:18.04/bionic-updates [amd64])
Conf grub2-common (2.02-2ubuntu8.23 Ubuntu:18.04/bionic-updates
[amd64])
Conf grub-pc-bin (2.02-2ubuntu8.23 Ubuntu:18.04/bionic-updates
[amd64])
Conf grub-common (2.02-2ubuntu8.23 Ubuntu:18.04/bionic-updates
[amd64])
stderr: ''
stderr_lines:
stdout: |-
libpam-systemd
updates [amd64])
[amd64])
[amd64])
[amd64])
[amd64])
[amd64])
[amd64])
stdout_lines:
- Reading package lists...
- Building dependency tree...
- Reading state information...
- Calculating upgrade...
- 'The following packages will be upgraded:'
- ' grub-common grub-pc grub-pc-bin grub2-common libnss-systemd
libpam-systemd'
- ' libsystemd0 libudev1 systemd systemd-sysv udev'
- 11 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
- Inst libnss-systemd [237-3ubuntu10.46] (237-3ubuntu10.47
- Inst libsystemd0 [237-3ubuntu10.46] (237-3ubuntu10.47 Ubuntu:18.04
- Conf libsystemd0 (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates
- Inst libpam-systemd [237-3ubuntu10.46] (237-3ubuntu10.47
- Inst systemd [237-3ubuntu10.46] (237-3ubuntu10.47 Ubuntu:18.04
- Inst udev [237-3ubuntu10.46] (237-3ubuntu10.47 Ubuntu:18.04/bionic-
updates [amd64])
- Inst libudev1 [237-3ubuntu10.46] (237-3ubuntu10.47 Ubuntu:18.04
- Conf libudev1 (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates [amd64])
- Conf systemd (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates [amd64])
- Inst systemd-sysv [237-3ubuntu10.46] (237-3ubuntu10.47 Ubuntu:18.04
- Inst grub-pc [2.02-2ubuntu8.21] (2.02-2ubuntu8.23 Ubuntu:18.04
- Inst grub2-common [2.02-2ubuntu8.21] (2.02-2ubuntu8.23 Ubuntu:18.04
- Inst grub-pc-bin [2.02-2ubuntu8.21] (2.02-2ubuntu8.23 Ubuntu:18.04
- Inst grub-common [2.02-2ubuntu8.21] (2.02-2ubuntu8.23 Ubuntu:18.04
- Conf libnss-systemd (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates
[amd64])
- Conf libpam-systemd (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates
[amd64])
- Conf udev (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates [amd64])
- Conf systemd-sysv (237-3ubuntu10.47 Ubuntu:18.04/bionic-updates
[amd64])
- Conf grub-pc (2.02-2ubuntu8.23 Ubuntu:18.04/bionic-updates [amd64])
- Conf grub2-common (2.02-2ubuntu8.23 Ubuntu:18.04/bionic-updates
[amd64])
- Conf grub-pc-bin (2.02-2ubuntu8.23 Ubuntu:18.04/bionic-updates
[amd64])
- Conf grub-common (2.02-2ubuntu8.23 Ubuntu:18.04/bionic-updates
[amd64])
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2600>
OSGeo <https://osgeo.org/>
