#2603: Patch update on lxd containers
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
Doing via ansible
make patch-update-containers command:
osgeo7_dronie-server
osgeo7_hop
osgeo7_nginx
osgeo7_nextcloud
osgeo7_secure
osgeo7_wordpress
osgeo3_hop
osgeo3_limesurvey
osgeo3_matrix
osgeo3_monitor
osgeo3_nexus
osgeo3_nginx
osgeo3_wiki
osgeo4_hop
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2603>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Changes (by robe):
* Attachment "lxd_container_patches_2021-05-16.txt" added.
Keywords: |
Comment (by robe):
All went okay except for matrix which appears to have a key expiration for
matrix packages. going to fix that and close once I've run for that.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2603#comment:1>
Keywords: |
Comment (by robe):
had to run on matrix
sudo wget -O /usr/share/keyrings/matrix-org-archive-keyring.gpg
https://packages.matrix.org/debian/matrix-org-archive-keyring.gpg
Then was able to run upgrade
ok: [osgeo3_matrix] =>
output_apt_before_upgrade:
changed: true
diff: {}
failed: false
msg: |-
Reading package lists...
Building dependency tree...
Reading state information...
Calculating upgrade...
The following packages were automatically installed and are no
longer required:
libc-ares2 libnode64 libuv1 python3-distutils python3-lib2to3
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
bind9-host curl exim4-base exim4-config exim4-daemon-light
libbind9-161
libcurl3-gnutls libcurl4 libdns-export1104 libdns1104 libisc-
export1100
libisc1100 libisccc161 libisccfg163 liblwres161 libpq5 matrix-
synapse-py3
postgresql-11 postgresql-client-11
19 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Inst matrix-synapse-py3 [1.30.1+buster1] (1.33.2+buster1
packages.matrix.org [amd64])
Inst bind9-host [1:9.11.5.P4+dfsg-5.1+deb10u3]
(1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-Security:10/stable [amd64])
Inst libbind9-161 [1:9.11.5.P4+dfsg-5.1+deb10u3]
Inst libisccfg163 [1:9.11.5.P4+dfsg-5.1+deb10u3]
Inst libisccc161 [1:9.11.5.P4+dfsg-5.1+deb10u3]
Inst libdns1104 [1:9.11.5.P4+dfsg-5.1+deb10u3]
Inst libisc1100 [1:9.11.5.P4+dfsg-5.1+deb10u3]
Inst liblwres161 [1:9.11.5.P4+dfsg-5.1+deb10u3]
Inst curl [7.64.0-4+deb10u1] (7.64.0-4+deb10u2 Debian-
Inst libcurl4 [7.64.0-4+deb10u1] (7.64.0-4+deb10u2 Debian-
Inst exim4-config [4.92-8+deb10u5] (4.92-8+deb10u6 Debian-
Security:10/stable [all])
Inst exim4-base [4.92-8+deb10u5] (4.92-8+deb10u6 Debian-
Inst exim4-daemon-light [4.92-8+deb10u5] (4.92-8+deb10u6 Debian-
Inst libcurl3-gnutls [7.64.0-4+deb10u1] (7.64.0-4+deb10u2 Debian-
Inst libisc-export1100 [1:9.11.5.P4+dfsg-5.1+deb10u3]
Inst libdns-export1104 [1:9.11.5.P4+dfsg-5.1+deb10u3]
Inst libpq5 [11.11-0+deb10u1] (11.12-0+deb10u1 Debian-
Inst postgresql-client-11 [11.11-0+deb10u1] (11.12-0+deb10u1 Debian-
Inst postgresql-11 [11.11-0+deb10u1] (11.12-0+deb10u1 Debian-
Conf matrix-synapse-py3 (1.33.2+buster1 packages.matrix.org [amd64])
Conf bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
Conf libbind9-161 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
Conf libisccfg163 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
Conf libisccc161 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
Conf libdns1104 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
Conf libisc1100 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
Conf liblwres161 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
Conf curl (7.64.0-4+deb10u2 Debian-Security:10/stable [amd64])
Conf libcurl4 (7.64.0-4+deb10u2 Debian-Security:10/stable [amd64])
Conf exim4-config (4.92-8+deb10u6 Debian-Security:10/stable [all])
Conf exim4-base (4.92-8+deb10u6 Debian-Security:10/stable [amd64])
Conf exim4-daemon-light (4.92-8+deb10u6 Debian-Security:10/stable
[amd64])
Conf libcurl3-gnutls (7.64.0-4+deb10u2 Debian-Security:10/stable
[amd64])
Conf libisc-export1100 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
Conf libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
Conf libpq5 (11.12-0+deb10u1 Debian-Security:10/stable [amd64])
Conf postgresql-client-11 (11.12-0+deb10u1 Debian-Security:10/stable
[amd64])
Conf postgresql-11 (11.12-0+deb10u1 Debian-Security:10/stable
[amd64])
stderr: ''
stderr_lines:
stdout: |-
longer required:
libbind9-161
export1100
synapse-py3
[amd64])
[amd64])
[amd64])
[amd64])
stdout_lines:
- Reading package lists...
- Building dependency tree...
- Reading state information...
- Calculating upgrade...
- 'The following packages were automatically installed and are no
longer required:'
- ' libc-ares2 libnode64 libuv1 python3-distutils python3-lib2to3'
- Use 'sudo apt autoremove' to remove them.
- 'The following packages will be upgraded:'
- ' bind9-host curl exim4-base exim4-config exim4-daemon-light
libbind9-161'
- ' libcurl3-gnutls libcurl4 libdns-export1104 libdns1104 libisc-
export1100'
- ' libisc1100 libisccc161 libisccfg163 liblwres161 libpq5 matrix-
synapse-py3'
- ' postgresql-11 postgresql-client-11'
- 19 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
- Inst matrix-synapse-py3 [1.30.1+buster1] (1.33.2+buster1
- Inst bind9-host [1:9.11.5.P4+dfsg-5.1+deb10u3]
- Inst libbind9-161 [1:9.11.5.P4+dfsg-5.1+deb10u3]
- Inst libisccfg163 [1:9.11.5.P4+dfsg-5.1+deb10u3]
- Inst libisccc161 [1:9.11.5.P4+dfsg-5.1+deb10u3]
- Inst libdns1104 [1:9.11.5.P4+dfsg-5.1+deb10u3]
- Inst libisc1100 [1:9.11.5.P4+dfsg-5.1+deb10u3]
- Inst liblwres161 [1:9.11.5.P4+dfsg-5.1+deb10u3]
- Inst curl [7.64.0-4+deb10u1] (7.64.0-4+deb10u2 Debian-
- Inst libcurl4 [7.64.0-4+deb10u1] (7.64.0-4+deb10u2 Debian-
- Inst exim4-config [4.92-8+deb10u5] (4.92-8+deb10u6 Debian-
- Inst exim4-base [4.92-8+deb10u5] (4.92-8+deb10u6 Debian-
- Inst exim4-daemon-light [4.92-8+deb10u5] (4.92-8+deb10u6 Debian-
- Inst libcurl3-gnutls [7.64.0-4+deb10u1] (7.64.0-4+deb10u2 Debian-
- Inst libisc-export1100 [1:9.11.5.P4+dfsg-5.1+deb10u3]
- Inst libdns-export1104 [1:9.11.5.P4+dfsg-5.1+deb10u3]
- Inst libpq5 [11.11-0+deb10u1] (11.12-0+deb10u1 Debian-
- Inst postgresql-client-11 [11.11-0+deb10u1] (11.12-0+deb10u1 Debian-
- Inst postgresql-11 [11.11-0+deb10u1] (11.12-0+deb10u1 Debian-
- Conf matrix-synapse-py3 (1.33.2+buster1 packages.matrix.org [amd64])
- Conf bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
- Conf libbind9-161 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
- Conf libisccfg163 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
- Conf libisccc161 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
- Conf libdns1104 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
- Conf libisc1100 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
- Conf liblwres161 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
- Conf curl (7.64.0-4+deb10u2 Debian-Security:10/stable [amd64])
- Conf libcurl4 (7.64.0-4+deb10u2 Debian-Security:10/stable [amd64])
- Conf exim4-config (4.92-8+deb10u6 Debian-Security:10/stable [all])
- Conf exim4-base (4.92-8+deb10u6 Debian-Security:10/stable [amd64])
- Conf exim4-daemon-light (4.92-8+deb10u6 Debian-Security:10/stable
[amd64])
- Conf libcurl3-gnutls (7.64.0-4+deb10u2 Debian-Security:10/stable
[amd64])
- Conf libisc-export1100 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
- Conf libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u5 Debian-
- Conf libpq5 (11.12-0+deb10u1 Debian-Security:10/stable [amd64])
- Conf postgresql-client-11 (11.12-0+deb10u1 Debian-Security:10/stable
[amd64])
- Conf postgresql-11 (11.12-0+deb10u1 Debian-Security:10/stable
[amd64])
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2603#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2603#comment:3>
