#2615: Partition remaining space on osgeo4
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Keywords:
Osgeo4 still had 1.8TB on sda and 1.8TB on sdb that were not partitioned.
I created a partiton sda3 to ext4 (mapped to /storage)
and the sdb3 to zfs format (this one is not mirrored by zfs like the as
I'm using it just for extra space for lxd in case it is needed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2615>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I've documented the steps on:
https://git.osgeo.org/gitea/sac/osgeo4/wiki/OSGeo4-Host-Setup
#create an ext4 partition on disk sda1
fdisk /dev/sda
#list free unpartitioned space
F
#add a new partition
n
# chose primary
#took the remaining defaults to claim the whole 1.8 TB
#write it out
w
# confirm new partition /dev/sda3 is there
fdisk -l
#format as extfs
sudo mkfs -t ext4 /dev/sda3
#mount it
sudo mkdir -p /storage
sudo mount -t auto /dev/sda3 /storage
#zfs disk
fdisk /dev/sdb
F
n
# chose primary
#write it out
w
# confirm new partition /dev/sdb3 is there
fdisk -l
#make it a zfs volume
zpool create -f lxd2 /dev/sdb3
zpool list #confirm there is now an lxd2
For now I'm just going old gallery before I moved it to osgeo3 on the
second disk, I plan to delete it in a couple of weeks and use the new
space to do bi-weekly backup of osgeo3/gallery
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2615#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2615#comment:2>
