#2624: grass-dev subscription bounced because osgeo6 failed to deliver to Runbox
Reporter: dovsienko | Owner: cvvergara
Type: defect | Status: new
Priority: normal | Milestone: Unplanned
Component: Mails & Mailing Lists | Keywords:
Hello support.
I have been a subscriber of the grass-dev mailing list for a while, and
recently my subscription started to bounce with the diagnostics below. As
far as I understand it, osgeo6 had tried to deliver the message in
IPv6-only mode, and Runbox is an IPv4-only service. That said, I have been
receiving the list messages up until today, so the best first place to
check seems to be osgeo6. Could you check please?
Thank you.
From: Mail Delivery System <MAILER-DAEMON@osgeo6.osgeo.osuosl.org>
To: grass-dev-bounces@lists.osgeo.org
Cc:
Bcc:
Date: Thu, 8 Jul 2021 04:33:21 -0700 (PDT)
Subject: Undelivered Mail Returned to Sender
This is the mail system at host lists.osgeo.org.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
<denis@ovsienko.info>: Host or domain name not found. Name service error
for
name=mx.runbox.com type=AAAA: Host found but no data record of
requested
type
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2624>
OSGeo <https://osgeo.org/>
