#2639: DMARC validation failed - header_from: faunalia.it
Reporter: pcav | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
We are receiving reports of failed DMARC validations for emails sent by
140.211.15.3 (osgeo6.osgeo.osuosl.org) with the following identifier:
<header_from>faunalia.it</header_from>
<envelope_from>lists.osgeo.org</envelope_from>
Some examples of the reports:
<?xml version="1.0"?>
<feedback>
<report_metadata>
<org_name>Verizon Media</org_name>
<email>dmarchelp@verizonmedia.com</email>
<report_id>1631582081.170348</report_id>
<date_range>
<begin>1631491200</begin>
<end>1631577599</end>
</date_range>
</report_metadata>
<policy_published>
<domain>faunalia.it</domain>
<adkim>r</adkim>
<aspf>r</aspf>
<p>none</p>
<pct>100</pct>
</policy_published>
<record>
<row>
<source_ip>140.211.15.3</source_ip>
<count>1</count>
<policy_evaluated>
<disposition>none</disposition>
<dkim>fail</dkim>
<spf>fail</spf>
</policy_evaluated>
</row>
<identifiers>
</identifiers>
<auth_results>
<dkim>
<selector>mail</selector>
<result>permerror</result>
</dkim>
<spf>
<domain>lists.osgeo.org</domain>
<result>pass</result>
</spf>
</auth_results>
</record>
</feedback>
<?xml version="1.0" encoding="UTF-8" ?>
<feedback>
<version>1.0</version>
<report_metadata>
<org_name>esa3.hc726-32.eu.iphmx.com</org_name>
<email>MAILER-DAEMON@esa3.hc726-32.eu.iphmx.com</email>
<extra_contact_info></extra_contact_info>
<report_id>803ff8$ba13321=3cf9959c31e36f60@esa3.hc726-32.eu.iphmx.com</report_id>
<date_range>
<begin>1631484004</begin>
<end>1631570403</end>
</date_range>
</report_metadata>
<policy_published>
<adkim>r</adkim>
<aspf>r</aspf>
<p>none</p>
<sp>none</sp>
<pct>100</pct>
</policy_published>
<record>
<row>
<count>1</count>
<policy_evaluated>
<dkim>fail</dkim>
<spf>fail</spf>
</policy_evaluated>
</row>
<identifiers>
</identifiers>
<auth_results>
<dkim>
</dkim>
<spf>
<scope>mfrom</scope>
</spf>
</auth_results>
</record>
</feedback
<feedback>
<report_metadata>
<org_name>Fastmail Pty Ltd</org_name>
<email>reports@fastmaildmarc.com</email>
<extra_contact_info>https://fastmail.com/</extra\_contact\_info>
<report_id>524846272</report_id>
<date_range>
</date_range>
</report_metadata>
<policy_published>
<aspf>r</aspf>
<p>none</p>
<sp>none</sp>
<pct>100</pct>
<fo>0</fo>
</policy_published>
<record>
<row>
<count>1</count>
<policy_evaluated>
<dkim>fail</dkim>
<spf>fail</spf>
<reason>
<type>trusted_forwarder</type>
<comment>Policy ignored due to
local white list</comment>
</reason>
</policy_evaluated>
</row>
<identifiers>
</identifiers>
<auth_results>
<dkim>
<result>fail</result>
<human_result>fail (message has been
altered)</human_result>
</dkim>
<spf>
</spf>
</auth_results>
</record>
</feedback>
Right now we have a "none" DMARC policy, but we are planning on enforcing
it in the near future. As far as I can understand, Osgeo misconfigured the
headers. If I'm not wrong, this could be a problem for many other domains,
so I thought it is of general interest and worth fixing.
Thanks for any intervention.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Changes (by pcav):
* Attachment
"esa3.hc726-32.eu.iphmx.com!faunalia.it!1631484004!1631570403.xml" added.
Keywords: |
Changes (by pcav):
* Attachment
"fastmail.com!faunalia.it!1631491200!1631577599!524846272.xml" added.
Keywords: |
Changes (by pcav):
* Attachment
"hostserv.co.za!faunalia.it!1631491200!1631577599!1412420.xml" added.
Keywords: |
Changes (by pcav):
* Attachment "yahoo.fr!faunalia.it!1631491200!1631577599.xml-1" added.
Keywords: |
Comment (by robe):
Is this for mail coming via mailing lists. I recall we had this issue and
we put in changes so mailing lists can fix this themselves. If it is
coming from mailing list can you be specific as to the mailing lists? If
it is some other mail e.g gitea or trac please let us know.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:1>
Priority: normal | Milestone: Sysadmin Contract 2021-II
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2021-II
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:2>
Keywords: |
Comment (by pcav):
Thank you. Yes, as far as I can tell they are coming from lists.osgeo.org.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:3>
Keywords: |
Comment (by robe):
You know which lists? I think it would be specific to the list as each
list has it's own settings. Take a look at #2475
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:4>
Keywords: |
Comment (by pcav):
We don't have any definitive evidence at this point, but we think that it
could be the lizmap list.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:5>
Keywords: |
Comment (by pcav):
I think the problem is rather serious, as it may trigger rejection of
valid messages from other domains.
We're available for more testing and action if we can be useful.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:6>
Keywords: |
Comment (by robe):
Is it just lizmap list you have trouble with? The lizmap admin if that
list should be taking care of that.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:7>
Keywords: |
Comment (by pcav):
AFAIK yes
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:8>
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2022-I
Component: Systems Admin | Resolution: wontfix
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
Going to close this out. I think it's a misconfigured mailing list so
requires mailing list admins to handle.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:10>
Keywords: |
Comment (by pcav):
is there a specific bugtracker for mailing lists?
Thanks.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:11>
Keywords: |
Comment (by robe):
No each mailing list admin manages their own mailing list. So I'm assuming
whoever is managing lizmap needs to be informed and configure their
dmarc_moderation_action to "munge from" as discussed in.
#2475
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:12>
Keywords: |
Comment (by strk):
I guess lizmap-owner should be informed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2639#comment:13>
