#2640: docs.geoserver.org website request
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
GeoServer PSC here proceeding with our migration plan away from Boundless
infrastructure.
We would like to request a home for docs.geoserver.org (which is presently
hosted by Planet Federal on Amazon S3).
We have the complete source code for the website, and would like to upload
content each month using a process similar to docs.geotools.org (well
exactly sample).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640>
OSGeo <https://osgeo.org/>
Priority: normal | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Resolution:
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2021-II
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:1>
Keywords: |
Comment (by robe):
Jive,
I think docs.geotools.org is currently hosted on osgeo6. I want to move
stuff off of osgeo6 so that it is dedicated to lists and mail.
That said do you mind if I put docs.geotools.org and docs.geoserver.org on
the same server. Maybe we can go thru the workflow you are currently
using to push the data and once it's good we can do a cut over.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:2>
Keywords: |
Comment (by jive):
I do not mind where the websites are stored at all, I assume they are low
traffic.
The build.geoserver.org Jenkins server is used to upload, let me check if
the script is in version control (or just in the Jenkins configuration):
Looks like it was Jenkins configuration (reproduced below, any
HOST=geotools@docs.geotools.org
DIST=`mvn help:evaluate -Dexpression=series -q -DforceStdout`
cd docs &&
mvn install
echo "website"
cd target/web/html
ls
if [ -e web.zip ]; then
rm -rf web.zip
fi
zip -r web.zip * &&
scp -oStrictHostKeyChecking=no web.zip $HOST:/home/geotools/$DIST
echo "user manual"
cd ../../../target/user/html
if [ -e userguide.zip ]; then
rm -rf userguide.zip
fi
zip -r userguide.zip * &&
scp -oStrictHostKeyChecking=no userguide.zip $HOST:/home/geotools/$DIST
echo "developers guide"
cd ../../../target/developer/html
if [ -e developer.zip ]; then
rm -rf developer.zip
fi
zip -r developer.zip * &&
scp -oStrictHostKeyChecking=no developer.zip $HOST:/home/geotools/$DIST
echo "documentation index"
cd ../../../target/index/html
if [ -e index.zip ]; then
rm -rf index.zip
fi
zip -r index.zip * &&
scp -oStrictHostKeyChecking=no index.zip $HOST:/home/geotools/$DIST
ssh -oStrictHostKeyChecking=no $HOST "svn up update_site.sh &&
./update_site.sh $DIST"
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:3>
Keywords: |
Comment (by robe):
Okay I'll start setting up something and we can test
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:4>
Keywords: |
Comment (by robe):
jive,
I moved geos.osgeo.org (will take a while for that change to propagate),
and the new libgeos.org to the new server. You can see the published docs
here https://libgeos.org/doxygen
To test via jenkins I have a job here:
https://debbie.postgis.net/view/GEOS/job/GEOS%20Publish%20Docs%20and%20Snapshot/
Which is admittedly a simple script but intent was just to test login and
run of script (your last part). I assume your scp stuff will work if that
works.
The script just has this:
HOST=debbie@geo-docs
ssh -oStrictHostKeyChecking=no $HOST "./geos-cron.sh"
In order to get that to work in the server I have jenkins running under
the account jenkins runs under. I created a .ssh/config file that has
this in it:
-- geotools is already a shell account (but might need the key registered
in ldap to pass thru the hop server) (debbie I added to shell group and
registered her pub key on her profile - https://id.osgeo.org/ldap/edit
(logging in with her account)
Host geo-docs
ProxyCommand ssh debbie@hop.osgeo3.osgeo.org -W geo-docs:%p
In your case it would be:
Host geo-docs
ProxyCommand ssh geotools@hop.osgeo3.osgeo.org -W geo-docs:%p
Let me know if this is doable for you. If you are able to publish I'll
move forward with getting the site ready (we can do a test drive with
something like docs.geoserver.osgeo.org, docs.geotools.osgeo.org etc.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:5>
Priority: normal | Milestone: Sysadmin Contract 2022-I
Keywords: |
Comment (by jive):
The build.geoserver.org is responsible for deploying to geotools already
(with jenkins secret used to store credential). I have now been able to
connect to geo-docs using my osgeoid.
What is the next step to start with docs.geoserver.osgeo.org? I expect we
need to setup a /home/geoserver location (but my account lacks
permission).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:7>
Keywords: |
Comment (by robe):
jive you are on the list of sudoers for geo-docs so you can sudo as anyone
and it should create the home folder when you do that. Then register any
ssh pub keys you need to that account.
I also see there is a geoserver account in ldap already -
it has cn sn = farhan petel. Is that someone in your group or a
completely different user?
geotools already has a home folder in geo-docs, so you could alternatively
use that one too for geoserver purposes if it's a different folder.
I will then need to know the path where docs are deployed so I can expose
that on osgeo3-nginx.
Can we have a jitsi meeting to go over the logistics of this. I'm
available now or anytime this week.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:8>
Priority: normal | Milestone: Sysadmin Contract 2022-II
Keywords: |
Changes (by robe):
* milestone: Sysadmin Contract 2022-I => Sysadmin Contract 2022-II
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:9>
Keywords: |
Comment (by jive):
I am not sure about that geoserver account.
Thanks for being patient I like to be careful with any system setup
activites…
So one option is use the existing geotools user and set up two folders:
/home/geotools/gt and /home/geotools/gs (and update deployment scripts and
apache to publish the new folders.
Is there any reason not to create a geoserver account to manage
/home/geoserver? Or is it the case that the “geoserver” name is already
taken in LDAP…
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:10>
Keywords: |
Comment (by robe):
It's because of the case that geoserver is already in ldap.
We could I suppose create a local geoserver account, but then you'd still
be using geotools account to hope into geoserver since you would need an
ldap account to pass the barrier. So that would just add extra confusion.
Maybe we can create a docgeoserver LDAP account? Would that be okay? If
so I can setup an email alias for that that goes to you so you can
register and manage it and reassign later if you want.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:11>
Keywords: |
Comment (by robe):
FYI. geoserver.org has transfered over to OSGeo. We need to resetup the
DNS entries and switch over the DNS authority since we don't have access
to the current DNS. If you have time this week, maybe we can go over that
to make sure transition is smooth. I think we need to have the doc server
ready first on OSGeo infra, perhaps as docs-geoserver.osgeo.org before we
make the DNS switch.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:12>
Keywords: |
Comment (by jive):
Now that we have record created - yay!
Do you wish to setup *docs-geoserver.osgeo.org* or something so we can
write the build job?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:13>
Keywords: |
Comment (by robe):
Sure I'll go ahead and do that for the geo-docs server. Maybe we should
do staging.docs.geoserver.org to make sure we really have control and
to make clear its for staging to confirm all is working.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:14>
Keywords: |
Comment (by robe):
Okay I created a dns for staging.docs.geoserver.org on osgeo3 and was able
to get to it and also generate a letsencrypt cert.
so do we want to go with a new account? or use geotools?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:15>
Keywords: |
Comment (by jive):
The build server is already setup with geotools credentials (it is like
gtbuild or something). I think you have started setting up geoserver user
which is also fine.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:16>
Keywords: |
Comment (by robe):
yah the geoserver user is geoserverdocs. Couldn't use geoserver, since
it's already taken by a mysterious masked man.
But anyrate it's okay for geotools and geoserverdocs to share the same
keys I think.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:17>
Keywords: |
Comment (by robe):
I've set this up, had to open up another ssh port for jenkins (but
whitelisted the ip just for new jenkins server). They are still
experimenting with push. The new is shown here:
https://staging.docs.geoserver.org/
Once they are settled, I will repoint docs.geoserver.org to this new
location.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:18>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Got rid of staging.docs.geoserver.org and now it is the official
https://docs.geoserver.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2640#comment:19>
