#2645: Trac login not working
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: blocker | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Keywords:
As mentioned in
https://lists.osgeo.org/pipermail/sac/2021-September/013583.html
LetsEncrypt intermediar SSL trust cert expried today which caused trac
login to break. Also causing a failure in id.osgeo.org (so creating
accounts is broken).
To fix the issue, I put in a temporary fix. Which I will detail in the
comment
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2645>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Both trac login and sshing into trac were broken.
As a stop gap fix, I turned off ssl cert verification. I will turn back
on after I have upgraded trac (which I will do next week).
To stop gap fixes
# to fix trac login
in /etc/apache2/mods-enabled/ldap.conf
I added a line right after the other LDAP settings
LDAPVerifyServerCert Off
To fix the SSH login issue
changed file:
/etc/nslcd.conf
changed line from demand to never
tls_reqcert never
To fix ldapsearch, I changed the file /etc/ldap.conf
TLS_REQCERT demand
to:
TLS_REQCERT never
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2645#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2645#comment:2>
