#2653: container OS updates for osgeo7, osgeo3, osgeo4
Reporter: robe | Owner: sac@…
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
#patch upgrades complete - the following servers upgraded.
Servers upgreaded OSGeo7
Dronie Server
The following packages were automatically installed and are no longer
required:
linux-headers-4.19.0-17-amd64 linux-headers-4.19.0-17-common
Use 'sudo apt autoremove' to remove them.
The following NEW packages will be installed:
linux-headers-4.19.0-18-amd64 linux-headers-4.19.0-18-common
The following packages have been kept back:
docker-ce
27 upgraded, 2 newly installed, 0 to remove and 1 not upgraded.
Download
The following packages will be upgraded:
apache2-utils base-files debconf distro-info-data krb5-locales
libgssapi-krb5-2 libk5crypto3 libkrb5-3 libkrb5support0
libmariadb3
linux-libc-dev mariadb-common psmisc python3-debconf tzdata
15 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Nextcloud
libnetplan0 netplan.io nplan
3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Secure
krb5-locales
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Inst krb5-locales [1.15-1+deb9u2] (1.15-1+deb9u3 Debian-
Security:9/oldoldstable [all])
Conf krb5-locales (1.15-1+deb9u3 Debian-Security:9/oldoldstable
[all])
Wordpress
linux-image-4.19.0-18-amd64{a}
apache2 apache2-bin apache2-data apache2-utils base-files debconf
debconf-i18n distro-info-data krb5-locales libapache2-mod-php7.3
libgssapi-krb5-2 libk5crypto3 libkrb5-3 libkrb5support0 libmariadb3
libnss-systemd libpam-systemd libssl-dev libssl-doc libssl1.1 libsystemd0
libudev1 libuv1 linux-image-4.19.0-17-amd64 linux-image-amd64 linux-libc-
dev mariadb-client-10.3 mariadb-client-core-10.3 mariadb-common mariadb-
server mariadb-server-10.3 mariadb-server-core-10.3 openssl php7.3
php7.3-bcmath php7.3-cli php7.3-common php7.3-curl php7.3-dev php7.3-gd
php7.3-intl php7.3-json php7.3-ldap php7.3-mysql php7.3-opcache
php7.3-readline php7.3-xmlrpc psmisc python3-debconf systemd systemd-sysv
tzdata udev
53 packages upgraded, 1 newly installed, 0 to remove and 0 not
upgraded.
Need to get 136 MB of archives. After unpacking 270 MB will be used.
Would download/install/remove packages.
osgeo3
hop
required:
dh-python exim4 gnupg-agent guile-2.0-libs libbind9-140
libcryptsetup4
libdns-export162 libdns162 libgdbm3 libicu57 libisc-export160
libisc160
libisccc140 libisccfg140 liblwres141 libncurses5 libperl5.24
libprocps6
libpython3.5-minimal libpython3.5-stdlib libssl1.0.2 libunistring0
python3-distutils python3-lib2to3 python3.5 python3.5-minimal
rename
sgml-base tcpd xml-core
base-files debconf distro-info-data krb5-locales libgssapi-krb5-2
libk5crypto3 libkrb5-3 libkrb5support0 libmariadb3 libssl1.1
mariadb-common
openssl psmisc tzdata
14 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
limesurvey - manually ran auto remove to remove the php 7.4 and changed
/etc/nginx/limesurvey.conf to use php 8.0
Calculating upgrade...
longer required:
php7.4-bcmath php7.4-cli php7.4-curl php7.4-fpm php7.4-gd
php7.4-gmp
php7.4-imap php7.4-intl php7.4-json php7.4-ldap php7.4-mbstring
php7.4-opcache php7.4-pgsql php7.4-readline php7.4-xml php7.4-zip
libk5crypto3 libkrb5-3 libkrb5support0 libpq5 php-imagick
php7.4-bcmath
php7.4-cli php7.4-common php7.4-curl php7.4-fpm php7.4-gd
php7.4-gmp
php8.0-bcmath php8.0-cli php8.0-common php8.0-curl php8.0-fpm
php8.0-gd
php8.0-gmp php8.0-imagick php8.0-imap php8.0-intl php8.0-ldap
php8.0-mbstring php8.0-opcache php8.0-pgsql php8.0-readline
php8.0-xml
php8.0-zip postgresql-13 postgresql-client-13 postgresql-client-
common
postgresql-common psmisc tzdata
matrix
'The following packages were automatically installed and are no longer
required:'
- ' libc-ares2 libnode64 libuv1 python3-distutils python3-lib2to3'
- Use 'sudo apt autoremove' to remove them.
- 'The following packages will be upgraded:'
- ' base-files debconf distro-info-data krb5-locales libc-ares2
libgssapi-krb5-2'
- ' libk5crypto3 libkrb5-3 libkrb5support0 libnss-systemd libpam-
systemd libpq5'
- ' libssl1.1 libsystemd0 libudev1 libuv1 linux-libc-dev matrix-
synapse-py3'
- ' openssl postgresql-11 postgresql-client-11 psmisc systemd
systemd-sysv'
- ' tzdata'
- 25 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
monitor
base-files debconf distro-info-data grafana krb5-locales
libgssapi-krb5-2
libk5crypto3 libkrb5-3 libkrb5support0 psmisc tzdata
11 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
osgeo3_nginx
base-files debconf krb5-locales libgssapi-krb5-2 libk5crypto3
libkrb5-3
libkrb5support0 libmariadb3 libssl1.1 mariadb-common openssl
psmisc tzdata
13 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
wiki
krb5-locales libgssapi-krb5-2 libk5crypto3 libkrb5-3
libkrb5support0
libmariadb3 libssl1.1 mariadb-client-10.3 mariadb-client-core-10.3
mariadb-common mariadb-server mariadb-server-10.3 mariadb-server-
core-10.3
22 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
=== osgeo4
hop
longer required:
libcryptsetup4
libisc160
libprocps6
rename
mariadb-common
osgeo9
hop
libk5crypto3 libkrb5-3 libkrb5support0 libssl1.1 openssl psmisc
tzdata
12 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2653#comment:1>
OSGeo <https://osgeo.org/>
