#2660: planet.osgeo.org is not refreshing
Reporter: jsanz | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords: planet, osgeo7
The OSGeo Planet does not show any new submission since September 29th. As
per [https://wiki.osgeo.org/wiki/PlanetOSGeo wiki] documentation the
planet now lives in OSGeo7, which I'm not familiar with.
For what is worth, I tested the planet configuration locally and builds
correctly.
Can someone take a look?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2660>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: planet, osgeo7 |
Comment (by robe):
Will look at in a bit. I suspect it might be the python version.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2660#comment:1>
Comment (by robe):
Okay was mistaken looks like it's because of the letsencrypt ssl issue.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2660#comment:2>
Comment (by robe):
Okay I think it's fixed. Just let it accept the svn.osgeo.org cert.
However I am worried some blogs might not be picking up because of the
letencrypt.
I'm planning to move planet to a newer server on osgeo3 (probably geo-docs
debian11 server). I just need to make sure the script will work (might
not as I think it relies on python 2.something).
I'm going to keep this ticket open until I have a new home for it.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2660#comment:3>
Comment (by robe):
jsanz for what it's worth -- you can get into the server
using osgeo7-old-webextra.
Instructions here -
https://wiki.osgeo.org/wiki/SAC_Service_Status#Accessing_osgeo7_containers_via_ssh
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2660#comment:4>
Comment (by jsanz):
Thanks a lot Regina!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2660#comment:5>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
was resolved a while ago
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2660#comment:6>
