#2690: Setup osgeo8 as LXD Host
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
osgeo8 as mentioned in #2591 I think we should go ahead and setup osgeo8
as an LXD host and use the disks as is.
It will be a host that will have both containers and VMs. I still need to
get around the lxd limitation that that while it can be used to create and
manage a true VM via QEMU, the default config has hardware emulation
turned off. This makes it only useful for non-linux VMS such as Windows,
Mac, the BSDs that don't need complete hardware emulation. Until we
figure out a way around it, we can't use it for hardware emulation - such
as emulating the os390s or the ARMs (which bare QEMU I think can do).
For the most part the container support (which is Linux Containers) is
sufficient to support any kind of Linux that is x86_64 (possible even
32-bit, haven't checked that).
That means even with the current osgeo8 disk, it should be pretty good for
CI/CD, demo sites, tutorial sites. Anything where we are often rebuilding
the thing from scratch and thus don't care as much that the disks may not
be robust.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2690>
OSGeo <https://osgeo.org/>
