#2701: Creating new tickets on osgeo4w trac instance fails: 504 Gateway Time-out
Reporter: strk | Owner: strk
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Trac | Keywords:
As reported on mantra-request list, attempts to crate a new ticket on
https://trac.osgeo.org/osgeo4w/newticket fails with this error:
I could reproduce a 504 Gateway Time-out
If this ticket was created this problem doesn't exist on
https://trac.osgeo.org/osgeo/newticket
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2701>
OSGeo <https://osgeo.org/>
Component: Trac | Resolution:
Keywords: |
Comment (by strk):
So, the ticket I tried to create was actually created, but it was so slow
that whatever proxy we have in the middle reported to my client the
Gateway Time-Out and I could not see the result of my ticket being crated.
The created ticket is here: https://trac.osgeo.org/osgeo4w/ticket/724
While adding comments to it I felt it was much slower than adding comments
in THIS instance of Trac. There could be some configuration or add-on
which makes the osgeo4w instance slower. You can feel that difference even
while only starting to type a comment in that ticket, as automatic preview
takes a very long time to come up too.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2701#comment:1>
Keywords: |
Comment (by robe):
I suspect maybe I didn't fix the mail handler. Before I repointed the
others to mail.osgeo.org it was doing that. So that one is probably still
trying to use trac for mail send. I forget if we have that ticketed to
investigate.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2701#comment:2>
Keywords: |
Comment (by strk):
I've updated the trac.ini for osgeo4w and it did seem to fix the issue.
I'd recommend filing a separate ticket for this.
BTW, the whole trac config (of all instances) is under a local git
repository, so I could see the change you were referring about and I could
add the new one. It'd be about time to commit those changes, don't you
think ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2701#comment:3>
Keywords: |
Comment (by strk):
https://trac.osgeo.org/osgeo/query?status=!closed&component=Trac doesn't
seem to show any ticket related to this
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2701#comment:4>
Type: task | Status: closed
Component: Trac | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2701#comment:5>
