#2709: Dronie-server looks like out of disk space
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Keywords:
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2709>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Increased allocated from 120G to 300 GB. The size is also used for
backups so should be bigger to allow for 30 days of backups.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2709#comment:1>
Keywords: |
Comment (by robe):
For future reference you can check allocated disk using:
lxc config show dronie-server |grep size
# allows you to directly edit any config
lxc config edit dronie-server
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2709#comment:2>
