#2714: osgeo7 nginx has broken config (host not found in upstream "old-adhoc.lxd)
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
Can't reload nginx on osgeo7-nginx due to the above.
The old-adhoc container is stopped, which is why reloading nginx fails
(doesn't resolve).
It looks like https://demo.mapserver.org/ is served from that
configuration so I'm not sure how that's possible with old-adhoc down.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2714>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
The VM was shutdown as per #2678
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2714#comment:1>
Priority: normal | Milestone: Sysadmin Contract 2022-I
Keywords: |
Changes (by strk):
* milestone: Unplanned => Sysadmin Contract 2022-I
Comment:
I brought up the old-adhoc container on osgeo7 to fix this issue, but I've
the impression we should be pointing at a *different* container instead ?
Note there are other 2 sites enabled that point at old-adhoc:
oam.osgeo.org (open areal map) and old.demo.mapserver.org (which is
currently down and we could thus just remove)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2714#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
The configuration was "fixed" by bringing up the `old-adhoc` container,
but I'm not sure what the correct fix would be. Will be discussed in #2678
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2714#comment:3>
