#2717: osgeo.org letsencrypt ssl cert renewal fails
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
Processing /etc/letsencrypt/renewal/osgeo.org.conf
Cert is due for renewal, auto-renewing...
Could not choose appropriate plugin: The manual plugin is not working;
there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with
--manual-auth-hook when using the manual plugin non-interactively.')
Attempting to renew cert (osgeo.org) from
/etc/letsencrypt/renewal/osgeo.org.conf produced an unexpected error: The
manual plugin is not working; there may be problems with your existing
configuration.
--manual-auth-hook when using the manual plugin non-interactively.').
Skipping.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2717>
OSGeo <Gter - OSGeo;
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
Same problem with foss4g.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2717#comment:1>
OSGeo <https://osgeo.org/>
#2717: osgeo7 osgeo.org and foss4g.org letsencrypt ssl cert renewal fails
Keywords: |
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2717#comment:2>
#2717: osgeo7-nginx: osgeo.org and foss4g.org letsencrypt ssl cert renewal fails
Keywords: |
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2717#comment:3>
Priority: normal | Milestone: Sysadmin Contract 2022-II
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2022-II
Comment:
I think the osgeo.org one might be a wildcard cert which I installed to
quickly replace the old expired one. I don't think we have any more
containers that rely on the wildcard so can probably be removed. I'll
double check on it to make sure. I suspect foss4g might be the same
story.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2717#comment:4>
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2023-II
Component: SysAdmin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
* milestone: Sysadmin Contract 2024-I => Sysadmin Contract 2023-II
Comment:
I think this was already fixed by Vicky when she was cleaning up
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2717#comment:7>
