#2718: osgeo4 backup is failing
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2022-I
Component: Systems Admin | Keywords:
This might be result of upgrade or something.
Error: Failed to run: zfs destroy osgeo7/containers/secure@snapshot-for-
osgeo4: cannot destroy snapshot osgeo7/containers/secure@snapshot-for-
osgeo4: dataset is busy
Error: Failed to run: zfs destroy osgeo7/containers/wordpress@snapshot-
for-osgeo4: cannot destroy snapshot osgeo7/containers/wordpress@snapshot-
for-osgeo4: dataset is busy
Error: Failed to run: zfs destroy osgeo7/containers/dronie-server
@snapshot-for-osgeo4: cannot destroy snapshot osgeo7/containers/dronie-
server@snapshot-for-osgeo4: dataset is busy
It sometimes resolves itself but sometimes doesn't and then a reboot of
osgeo7 is required or explicitly unmount / mount the containers.
I think the script also needs some work as it looks like it deleted the
backups even though taking a snapshot failed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2718>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Okay this is a different issue than what I though. Usually when this kind
of thing happens with making snapshots, I can't make snapshots at all and
it gives a different error.
I can snapshot these servers fine with
lxc snapshot secure
lxc snapshot wordpress
lxc snapshot dronie-server
However if I try to delete
lxc rm dronie-server/for-osgeo4
I get this error:
Failed to run: zfs destroy osgeo7/containers/dronie-server@snapshot-for-
osgeo4: cannot destroy snapshot osgeo7/containers/dronie-server@snapshot-
This I have only seen happen if osgeo4 is in the middle backing up the
container in question.
Checking osgeo4 - it is in middle of backup of pretalx on osgeo3 which
shouldn't impact osgeo7
sudo ps -faux | grep "lxc copy"
shows:
lxc copy osgeo3:pretalx/for-osgeo4 pretalx-backup
So only thought I have is osgeo4 must still have a hold on it when it
tried to delete the snapshot to reuse the name. I suspect rebooting
osgeo4 should resolve this. But should wait till it's done with backups.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2718#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
closing this out since last scheduled backup on these ran fine. dronie-
server one I manually ran since that only backs up every 2 days.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2718#comment:2>
