#272: enable pre-revprop-change hook
Reporter: jef | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: normal | Component: SAC
Keywords: |
I unsuccessfully tried to fix a wrong commit message in the QGIS
repository. Could that be enabled?
$ svn propset -r 8760 --revprop svn:log "fix #924"
svn: DAV request failed; it's possible that the repository's pre-revprop-
change hook either failed or is non-existent
svn: At least one property change failed; repository is unchanged
svn: Error setting property 'log':
Repository has not been enabled to accept revision propchanges;
ask the administrator to create a pre-revprop-change hook
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/272>
OSGeo <http://www.osgeo.org/>
Reporter: jef | Owner: sac@…
Priority: normal | Component: Systems Admin
Keywords: |
Comment(by crschmidt):
In general, allowing all users to edit svn:log messages feels like a Bad
Idea to me. Some messages are bad, and that sucks, but allowing for the
revision of history in this manner feels dangerous to me.
I would advise against this as policy, but if you would still like me to
enable this behavior, I will do so.
(Obviously, this request is a bit out of date; if you are no longer
interested, just close the ticket.)
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/272#comment:1>
Keywords: |
Comment(by jef):
Replying to [comment:1 crschmidt]:
Any better solution? If a log message is wrong, I'd like to fix it.
No, it's not out of date. http://trac.osgeo.org/qgis/changeset/8760
still says that it's fixing http://trac.osgeo.org/qgis/ticket/934 instead
of http://trac.osgeo.org/qgis/ticket/924. And there's currently no way to
fix that.
Without this ticket it would have take much more time to figure out what
changeset {{{r8760}}} is for.
But would TRAC notice log changes at all?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/272#comment:2>
Type: task | Status: closed
Priority: normal | Milestone:
Component: Systems Admin | Resolution: moved
Keywords: |
Changes (by jef):
* status: new => closed
* resolution: => moved
Comment:
qgis is using git for years.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/272#comment:3>
