#2729: OSGeo6 change to run postfix not in backward compatiblity mode
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Keywords:
So I added a new dmarc alias entry on osgeo6
as detailed in https://wiki.osgeo.org/wiki/Osgeo6#Postfix_SMTP_server
Upon reload, I got this notice:
postfix: Postfix is running with backwards-compatible default settings
postfix: See http://www.postfix.org/COMPATIBILITY_README.html for details
postfix: To disable backwards compatibility use "postconf
compatibility_level=2" and "postfix reload"
postfix/postfix-script: refreshing the Postfix mail system
I presume this is a result of my last upgrade to stretch.
That said we should probably not be running in backward compatibility
mode but will need to review to see what kind of things might break before
I switch mode
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2729>
OSGeo <https://osgeo.org/>
