#2740: Pretalx updates
Reporter: lucadelu | Owner: sac@…
Type: task | Status: new
Priority: major | Milestone: Unplanned
Component: Systems Admin | Keywords: pretalx
Dear SAC,
could I ask to update pretalx container? The review pages is wrong
formatted and we would like to test if newer version resolve this problem.
Inside the deployment there all the submissions of FOSS4G 2022 so please
take care
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2740>
OSGeo <https://osgeo.org/>
Priority: major | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Resolution:
Keywords: pretalx |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2022-II
Comment:
Okay I'll test on osgeo4 first.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2740#comment:1>
Keywords: pretalx |
Comment (by robe):
I started up https://talks.staging.osgeo.org
and upgraded the pretalx (main to latest pretalx docker image) and applied
latest main branch of public-voting and pages. I didn't restore data from
production since I didn't want any unintentional emails going out.
Hopefully this is good enough for you to test. If it looks good to you I
can install the same image on production.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2740#comment:2>
Keywords: pretalx |
Comment (by lucadelu):
It seems good to me, you can install the same image. Just to understand
better, are the data in a different container/image/database?
Thanks a lot
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2740#comment:3>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: pretalx |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Done.
The docker setup is composed of 3 containers:
1) pretalx (only one I updated)
2) mysql
3) redis
The data is stored in docker volumes and setup config in a folder so is
not gone when we swap out the images
The staging has different data from production (osgeo3-pretalx) and
staging is on a completely different server (its on osgeo4-pretalx-
staging). I use staging to build the docker images and then push it to
repo.osgeo.org (our local docker registry).
Then on production I pull down the latest built image from our local
docker registry and then run.
Steps are
#this is needed because takes a bit for things to start up
export COMPOSE_HTTP_TIMEOUT=100
docker pull docker.osgeo.org/sac/pretalx-osgeo:latest
docker-compose down
docker-compose up -d
docker-compose logs -f # to monitor things are running okay
hope that clarifies things
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2740#comment:4>
