#2742: id.osgeo.org reset password not working
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
Someone just complained about this.
I tested with my test account and ran into the same issue.
Steps to produce:
1. Go to https://id.osgeo.org/reset -- type in your email
and then submit
Works - get an email with a reset link that says
Click the button below to confirm password reset of user with ID
"yourusername is here".
2. Go to reset link - and click Confirm
FAIL
**Password reset script returned false**
This worked fine when testing as staging.id.osgeo.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2742>
OSGeo <https://osgeo.org/>
Reporter: robe | Owner: strk
Type: task | Status: assigned
Component: Systems Admin | Resolution:
Keywords: |
Changes (by strk):
* status: new => assigned
* owner: sac@… => strk
Comment:
Confirmed, and should now be fixed. Can you please double-check before
closing this ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2742#comment:1>
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2022-I
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: assigned => closed
* resolution: => fixed
* milestone: Unplanned => Sysadmin Contract 2022-I
Comment:
Confirmed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2742#comment:2>
