#2743: unable to change highlighted event on home page to foss4g
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
Or indeed edit the home page content at all, perhaps due to recent update
(https://trac.osgeo.org/osgeo/ticket/2695).
Previously the home page presented with boxes to fill in for the different
columns ("Helping you succeed", etc...). And you could select the event to
be highlighted from the list of upcoming events.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743>
OSGeo <https://osgeo.org/>
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Resolution:
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2022-II
Comment:
ah okay I see you already submitted a new ticket. Checking it out now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:1>
Keywords: |
Comment (by robe):
@jive,
I'm thinking maybe I missed updating the plugins and the plugins needed to
be updated as well.
I'm not quite sure what I should be seeing though. I just updated it to
5.9.2 and updated all the plugins. Now when I go to edit, I see this:
[[Image(osgeo_home_edit.png)]]
Before I think that section was cut off.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:2>
Keywords: |
Changes (by robe):
* Attachment "osgeo_home_edit.png" added.
Keywords: |
Comment (by jive):
Thanks, that is more what I was expecting to see.
Reading down the page the events - are now empty!
And the highlighted event is foss4g 2021 ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:3>
Keywords: |
Comment (by jive):
I do not see those options, perhaps you are taking a screen snap from
staging?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:4>
Keywords: |
Comment (by robe):
I double-checked production, the screen shot above is what I see on the
Info tab. The highlight tab however doesn't include a drop down for page
where as in staging it does have a drop down. I'm assuming this is just
an intentional difference because even after upgrading staging to 5.9.2, I
still see the drop down.
For comparing - staging highlight tab looks like this:
[[Image(staging_highlight.png)]]
The Highlight tab though doesn't seem to allow you to pick a page on
production. production highlight tab below:
[[Image(production_highlight.png)]]
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:5>
Keywords: |
Changes (by robe):
* Attachment "production_highlight.png" added.
Keywords: |
Changes (by robe):
* Attachment "staging_highlight.png" added.
Keywords: |
Comment (by robe):
@jive,
FWIW last time I saw a broken behavior when upgrading wordpress it was
caused by cached javascript files on my local browser. Doing a force page
load or clear cache reload fixed the issue. If you are not seeing the
same thing as I see above, I suggest clearing your browser cache. If you
still don't see the above, you might have a browser plugin blocking some
javascript from loading.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:6>
Keywords: |
Comment (by jive):
Checking:
- So the homepage now shows "FOSS4G 2022 Firenze (Italy)" under events -
as the only upcoming event (I hope we have more?)
- The homepage highlighted event is still FOSS4G SotM Oceania 2021.
Editing homepage:
- I still do not see any options to do anything
Editing homepage on staging:
- tab header: I can see options to edit title, subtitle, call-2-actions
- tab intro: description, image, and more ...
- tab highlight: has "FOSS4G 2021 September 27th to October 2nd
2021", so that is good I can change it
So what is different about staging?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:7>
Keywords: |
Comment (by robe):
You have some time to meet today?
I see both sections in staging and production. So I think I'm still
missing something here.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:8>
Keywords: |
Comment (by robe):
I should add I did upgrade staging to same wordpress version as production
So differences are
1) Different data
2) I can't upgrade Advanced Custom Fields PRO on staging since it doesn't
have a license so it is at Version 5.8.9 where as production is at 5.12.1
(there is a 5.12.2 update I haven't installed yet which I'll do later this
weekend with next patch update of wordpress).
I don't really notice much of a difference between the two aside from the
data differences. If it is the ACF difference you are seeing, that could
easily cause the cache issue I was talking about above that would be
cleared with clearing your browser cache.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:9>
Keywords: |
Comment (by jive):
Oh interesting, so we are seeing different things?
I will try clearing my browser cache.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:10>
Keywords: |
Comment (by jive):
Cleared cache, same result.
Tried a complete different browser, same result.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:11>
Keywords: |
Comment (by robe):
If you have time to meet today or tomorrow maybe we can go over to make
sure we are talking about the same thing.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:12>
Keywords: |
Comment (by jive):
tomorrow is good, I expect you are asleep now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:13>
Keywords: |
Comment (by robe):
nope I'm still awake. I can do now if you are up for it. The jitsi link
I sent earlier to you.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:14>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
All set but still mysterious. Jody and I were able to resolve the issue.
Had something to do with permissions is our guess.
To fix I unchecked the Administrator permissions on Homepage and then
saved and then rechecked.
Then miraculously Jody was able to edit too.
Why he couldn't before and I was able to when we both had administrator
role is puzzling.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2743#comment:15>
