#2751: Fix osgeo6 ldap ssh auth so it reads more than one ssh pub key from ldap
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Keywords:
osgeo6 has the old ssh-ldap script. Unfortunately that one only seems to
read the first ssh key from ldap. I noticed the issue after adding
multiple to my account.
The one that strk installed on hops via ansible can handle multiple.
This ticket is to change osgeo6 to use that one.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2751>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Testing mail ignore.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2751#comment:1>
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Just deployed to use same script as others.
Having lnicola test since I gave him access and he couldn't connect before
because he had two ssh keys registered. the new script should properly
handle that case.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2751#comment:2>
