#2765: Some OSGeoLive reports broken as result of upgrade
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Keywords:
Just noting this in case others using trac reports run into the same
issue.
As a result of the upgrade 4 of the OSGeoLive reports were broken. I
think this is result of trac in newer version adding the description field
to other tables. Before I think it was only on the tickets table.
Easy fix.
The error it gives is something to the effect
ambiguous column description
The fix is to prefix the description column with the alias for tickets
which is usually t.
So
SELECT .., description AS _description
becomes
SELECT .., t.description AS _description
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2765>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2765#comment:1>
#2765: Some OSGeoLive trac reports broken as result of trac upgrade
Keywords: |
Changes (by robe):
* summary: Some OSGeoLive reports broken as result of upgrade => Some
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2765#comment:2>
Keywords: |
Comment (by robe):
just in case someone is searching for the error, the exact error was
ProgrammingError: column reference "description" is ambiguous
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2765#comment:3>
Keywords: |
Comment (by kalxas):
Thank you for the fix!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2765#comment:4>
