#2767: Pretalx fail to upload file
Reporter: lucadelu | Owner: sac@…
Type: task | Status: new
Priority: major | Milestone: Unplanned
Component: Systems Admin | Keywords: pretalx, ngix
Dear Robe,
we are facing a problem uploading file, it return ngix problem "413
Request Entity Too Large".
I'm not able to replicate the problem on [https://talks.staging.osgeo.org/
staging] since it is not working
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2767>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: pretalx, ngix |
Comment (by robe):
@lucadelu. Okay I'll check it out and also turn staging back on.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2767#comment:1>
Comment (by robe):
Can you give it a try again. I did it on production. If it doesn't work
then I'll turn on staging so we can experiment.
I noticed I was missing the client_max_body_size setting I have for other
nginx configs so might have been using the default which I think is like
2MB. Hopefully that will fix it.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2767#comment:2>
Priority: major | Milestone: Sysadmin Contract 2022-II
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2022-II
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2767#comment:3>
Comment (by lucadelu):
Yes, it works now. What is the new maximum size?
Thanks a lot
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2767#comment:4>
Comment (by robe):
I set it to infinite on the nginx side, but pretalx might define it's own
upper limit.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2767#comment:5>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2767#comment:6>
